There are procedures for utilizing waste heat from internal combustion engines, one is the TEG process (thermoelectric element), the other is BMW Steamer. We have already discussed this method at Heat pump or generator using heat flow. However, when one examines all these procedures, one returns to the beginning and sees that the simplest and also the most effective method is to gasify wood and use gas directly in the engine.
