Using retort gas as engine fuel
Hello, can we safely use the gas coming out of a charcoal retort as fuel for a generator, assuming it has travelled through a condenser and cooled to ambient?
Are there nasty things in the retort gas that are bad for the engine that will not condensate out at ambient temperature?
My assumption was that as long as the gas was cool and no moisture was condensing out, it was at that point safe to use in an engine. Perhaps a bad assumption.
Here is a quote from the Sonoma Biochar initiative instruction manual for the Adam Retort that made me ask about this:
When feasible, it is highly efficient to further use the energy produced by running the retort. The unit re-burns
gas to continue the retort processes. Further use of the produced gases could fuel an engine/generator or a
boiler (details on these optional techniques are outside the scope of this document).
Here is a picture of what I am describing.
I think you would be better off to enclose the retort in a firebox and use the retort gasses to provide most of the conversion heat required. There are a lot of retort ideas around but the one i’m proposing that has been done a lot is basically a barrel in a bigger barrel with twigs and trash wood taking up the extra space. Light the trash and it heats up the inner barrel retort to the point that the inner barrel gases ignite and drive the reaction. I believe your proposal is a lot of filtering and cleaning that would remove most of the benefits of the simpler fuel that is charcoal.
Hello David,
You asked this in the General Discussion section not a Charcoal section.
So I will respond.
What purpose are you making your charcoal for?
There is no wrong answer to this. It is not a trick question.
Most charcoal for personal use fuels guys are using the driven off combustable gases as additional heat energy to be able to charcoal convert wetter, green cut woods.
Yes I like how many designs recirculate the gasses to fuel the charcoal production cycle. I currently make charcoal in an even easier method of TLUD (aka fill a barrel with wood and poke holes in the bottom and light from the top).
I thought it would be nice to have the tar as a byproduct, I hear it is good for fence posts
The purpose is for the charcoal gasifier, I am building Matt’s ‘Ammo box’ build. I currently make it with a TLUD but wanted some tar and wood vinegar from the process
I guess I just figured, if I’m condensing out the byproducts, maybe I could use the gas at the end for something. If not, I will just feed it back to the fire underneath the retort as suggested
David,
Feeding the gas back underneath the retort is probably the best idea for utilizing the gas. Figuring a way to utilize the heat might be the way to go.
You could dedicate a retort purely for distillation and still use the excess gas to self heat the retort. But you’d likely want water cooled condensers. Imagine an alcohol or essential oil still. All the byproduct would be useful in some way, but if you want a lot of charcoal you’re best off with a TLUD like you have now or a full self heating retort in my opinion.
Because this wont be full time. I think heating water would be easiest and the best way. That alone brings some desire to want to use it.
This Spring I was planning to do just that. I have a 30, 16 and 10 gallon drums to play with. The inner drum I was just going to install a center tube so the gasses excape at the top and migrate down the botton and exhuast out. The Ill create a fire chamber basically just a ledge for the inner drum to rest on and then opon chamber to feed fuel into. Then chimney out the top. MIght intall this in the shop for shop heating. When done we will just have to fire up the torpedo heaters to let it cool down to where we can handle it and install a new batch of wood. Could have mutliple inner drums ready and you just swap them out.
What you are proposing is a ‘closed’ retort. IIRC there is a thread on wood vinegar, which is essentially what you are aiming for, but I think there are several video’s in there of various ‘still’ designs. Most of them use a long pipe with a slight vertical rise for the condenser. sometimes they drape wet clothes on the vertically rising pipe. Or some just use a water bath cooler.
I should mention, that typically, they collect everything, then let it settle out, and in theory (I didn’t get it to work right but that isn’t completely unsurprising) that it settles out into 3 layers over a few months, the bottom layer is the tar, the middle layer is the wood vinegar, and the top layer is mostly water.
Because it is distillation with a pot still, check your local laws about having a ‘still’.
Tlud designs seems to be what most people settled on. Low cost and easy to implement at scale. I liked it to make large volume quickly. For using the heat I used to make it in my woodstove.
