I get that he is making a motor, but im not seeing free energy.
Iād kind of like to explore this but itās a ways beyond the capabilities of my pea brain. However I know that all matter; every cell of every plant or animal, functions electromagnetically. That the universe is an ocean of energy is a well known axiom. Whether this guys efforts are capable of focusing that energy is outside my wheelhouse however We were given a demonstration of zero point technology a couple months ago when drones hovered over New Jersey for 6 days. New tech is outpacing our ability to power it with our basically antiquated power grid. We really need to think in terms of focused and channeled energy rather than generated and metered energy. probably not in my remaining years, but many of you will see this shift.
I canāt figure out what he is trying to do. It is a motor/generator. but all he is doing is increasing the voltage, but when you do that the amps go down. Which he knows.
watts = volts * amps.
He isnāt using capacitors which he also knows are better at capturing high voltage instant currents like he is trying to produce.
Honestly, I think he is a scammer basically trying to get people to pay for this experiment, and he is claiming his battery bank was 5k dollars and it is what 5 used lead acid batteries.
TomH.
I strongly prefer rational, reasoning explanations such as here:
Rather than jabber doodle-do about the universe of energy we live in I judge all presentations by a few simple premises . . .
Does this systems require Belief to work? My Belief? A whole collection of others Beliefs?
And does this buy-in Believing require me to suspend my own natural rational reasoning?
I eat a tablespoon of honey every morning because I believe to will have health benefits for me. I get the honey because thousands of bees slaved themselves, and their lifespans collecting wide spread only seasonally produced plants nectar. The nectar made up by plants from solar input energy input as part of their own needed lifecycle.
So I am eating stored solar energy then? Some, yes.
But wait: on the two steps I pointed out to make the honey for me there is thousands and multiple hundreds of thousands of cells-units of living life force involved.
That is an input too. So I am directly befitting from collected up, concentrated, and serve to me universal lifeforce too? Yes. I think so.
My peabrain cannot explain the life-forces inputs involved. But I do not need to believe in it for it to exist.
After all it has a Life of its own. (pun-joke)
Morally, ethically I resolve in my mind benefiting from hundreds of thousands of other life forces by not slaving them into extinction. By not turning myself into a Pharaoh, Caesar, High-Priest, Warlord, President-for-Life or one of the many whipping acolytes needed to support from many many diffused mini-inputs a high focused pointed pyramid power structure.
Universal energy sources are very spread out and not concentrated at all.
The āfreeā goes away when your capture/concentrator-to-useable device will have to be ginormous.
It has been known since they figured out the earth vibrates. I donāt like that lady, she is a moron most of the time.
Quotes from the video: " the worldās laziest power source." āIt would take a Billion years to charge your phoneā
Makes a hand-full of thermocouples look like a power plant at Niagara Falls.
Or some of the piezo electric generators in your shoes. ![]()
Good Morning All
I am now experiencing my third AGM premature battery failure in the past ten years. Different brands using different assembly styles. Spiral wound plates; and flat vertically hung plates.
These have been all vehicle starting and accessory load applications. So not precisely bank load applications.
So looking to what Iāve been doing wrong, not-best.
Here:
My personal solutions are relatively easy . . . I can still get wet flooded lead acid batteries. They are cheaper and more tolerant of sitting unused. Most I can then go back to old-school monitoring with a hydrometer cell to cell acid conditions. Observing charging outgassing.
AND . . .
Ditch out of the older dumb-dumb battery chargers. Even the good oneās with auto-off will not continually battery-state-of-charge sense; and turn themselves back on.
Use now only multi capable, newer solid state smart chargers.
On chargers . . . never use direct Boost chargers for vehicle starting. Always been hard on the charger. And now with electronics laden vehicles a poorly made; or damaged; internally degrading charger can give fits to the vehicle systems. Kicking out AC chatter onto the DC output line. This gets seen as digital signaling. Confusing. Or output spike a high enough voltage that an EEPROM module chip is erased. Smart then made very dumb.
As this Camping-man says use 10, 20 amp smart chargers. Then just spend the little bit of time to get up to a batteries minimal cranking capability. Take time. Be safe.
YMMV
Steve,
In your vehicle lead-acid battery arsenal, are you using starting batteries or marine batteries?
Both.
Two because of under hood space have smaller cased starting batteries.
The other four are oversized case Group 31Pās Marine/RV deep cycle batteries. These have been fine even in our mild winters for starting the Hyundai 2.7L DOHC V-6; the Ford 5.0L V-8; and the GMC 6.0L V-8.
All are labeled Marine/RV. Two are direct bought Interstates āDeep Cycle 840 Marine CCA, 210 RCā semi-sealed, vented. The last two bought are Tractor Supply TRAVELERS by Interstate āHigh Cycling 950 Marine CCA, 195 RCā fully pop caps topped.
Marine CCA is at 32F/0C.
Ha! Cost me two more hornet stings looking under hoods:
One nest by the underhood drivers edge. The other under, by the hood loop latch.
Iāll go find my flung-off good eyeglasses after dark. They are still pissed. Me too.
Works out in the country, but does not work in the city too much interference for ground phone system to work.
Thatās no fun. I learned to always fill the hollow rungs of aluminum extension ladders with spray foam because you donāt want to get twenty feet up one and have them come pouring out after you. In one such debacle I got stung twice in the nose. I looked like WC Fields.
This isnāt quite woodgas, but it is hilarious and could be used as a chunker⦠It just needs to be posted somewhere.
If you love automation, gadgets, and having many alternatives here is a video for you. Watch with the sound turned up for a taste of my rainy winter world:
So, Mr Korean man what is real-world complications missing??
A partner/spouse/Wife, and children. Then ācamping outā gets real interesting. And youāll find truly: less-is-more. Less things to have to un-screw-up from the many fingers of mischiefs. Less loose widgets; bits and pieces to have gotten legs and walked off. Gone lost.
The inside of that popup is going to get coated with cooking grease over time. Not for me.
I have had one grease fire, and there is no way, I am doing any sort of grease inside with wooden floors, no countertops and an open flame. Then the residual smell of the grease and whatever you cooked⦠I am sure a bear would be interested.
It is an outside sport with a separate cook tent.
Advertisement for that cooking brand. I dont know about you guys but we take only one or maybe two devices, not ten. The television gadget was funny. Looker like the movie Vacation and an angry navigation.
Me and my wife went away for a weekend a few years back and the kids took the oportunity to throw a party. Neigbour called me 7.30 in the morning and asked when it ever ende! What? I am not home , hung up and started his biggest chainsaw until we arrived in the evening. No mather what they did , we found out. One of the kids reprogrammed the Google Chrome box into Korean ( or likewise)
Never worked properly again
. Not my thing but my wife was happy with it.
Gadgets have to serve you or you become slave of your gadgets.
A cogent video of the state of things to come. Relevant to this group because we are self determining and not just the pawns of a global design constructed to reduce the majority of humanity to an easily manipulated commodity.
