Texas has been adding storage to the grid, they have 8gw now, and are projected to have 18gw by the end of the year. Batteries are pretty instant recovery. The original plan I saw was to distribute them around the grid specifically for grid regulation purposes because they have some pretty remote areas, and long stretches that have frequency issues.
The second issue they have is they are putting solar out west, and most of the population is in central or on the east coast, and actually most of the use is probably around houston so they are looking at what 500 miles. Houston has grid issues, I don’t know why they have been resisting solar.
Ok this ones is way way too good , hope you can see it
Football season has started here again and here Andy Griffeth back in 1953 tried to figure out what it was all about. https://www.youtube.com/watch?v=oNxLxTZHKM8
Yes, batteries will also work, but they cost roughly twice as much. The conclusion in the guy’s masters thesis.
Batteries are instant, and most other forms of energy have a spin up time. Most likely his paper isn’t right.
if you are looking at purely frequency regulation, his paper is probably correct. IF you are looking at grid management as a whole. It is less likely because ultimately you don’t need to load follow which is a guessing game as to what future demand will be because it takes time for new generation to come online. Do you need a hot spare gigawatt power plant if you have a 8 gigawatt hour battery system? it buy 8 hours to start up a gigawatt power plant. If you have 100mw/hrs of batteries, you can tighten the margins of extra capacity available in case of a surge in demand. So instead of say 5%, you can cut that right down to 1%. any surge gets picked up by the battery until extra generation can come online.
The point is you are eliminating the guesswork which saves money, and you don’t have to have extra generation online which saves money even if you never use the batteries. However, it does hurt the power generation company’s bottomline.
Hi All
I just changed the engine oil on the wife’s 2022 Toyota Highlander Hybrid.
Sheee . . . one year now she has had this 40 mpg fuel sipper. She’s put 30,000 miles on it in the last 12 months. (Why will not this be 70 y.o. nurse just retire, eh?)
Anyhow I have been bumping up the in-the-US specified 0W-16 oil to a premium 0W-20.
No problems, no issues at all created.
Now I’ve just watched this video:
Modern Suburu lovers especially need to watch and listen to this guy well.
And those with cylinder deactivation systems need to search out defeat options.
Same with the majority of the run-stop systems.
Will I ever bump up to a 5W-20 oil on her car??? Maybe. Maybe not. It actually runs the engine only partial time; so the average engine temperature is low-low. NOT a modern expected constant oil thinning high temperature. And even with Toyota’s dual direct and port injection systems I am seeing, smelling accumulative gasoline fuel dilution of the engine oil. Crazy, foolish to go with long oil change intervals on this system!
For sure DIY your own oil changes to get back control, and decisions.
And this is what I believe sincerely DIY using wood-for-your-power is all about. Seizing back some control and responsibly for your Life.
whelp. I never thought something like this would be sorta woodgas related
 yet here we are.
Tom, that gave me a good chuckle. I didn’t know about rear mounted transmissions :smile:
To be able to wrap your head around some forign expressions isn’t always easy. My favorite Finn is an expert though.
Hilarious J.O.
To understand the usage of ass by Americans you have to know our history.
The extensive use in the 19th century of mules as work animals. Mules: the hybrid between a horse and a donkey. They were called asses.
So more than half the time we are not referring to the poop-hole, or the body parts surrounding the poop-hole; but a stubborn, cantankerous critter that was better than a horse IF you could get it to work.
Everyday usages gets emphasis sprinkled into a cultures language.
“I gave it my all!” becomes, “I gave it the whole nine yards!” The length found best for late 1930’s, 1940’s fighter aircraft 50 caliber machine guns cartrige belts.
A video for Goran’s history collection. You may have already seen this.
Interesting pictures, but most seem unrelated to the narration. High power-to-weight ratio at 2200 pounds and 140 hp continuous, 200 hp peak? I wonder if there’s AI in the background. The efficiency numbers are impressive, but it only compresses air. By the time you convert the compressed air to another useful form, you may well have given back a lot of that efficiency. Good for generators for spacecraft though (edit: with a nuclear heat source, not really an ICE).
Hi Tom, interesting video, but seems some ai generated?
As i know it the Ljungström free piston engine was more of a curiosity, not really much development in Sweden, more in other countries.
But some boring facts and coincidenses: STAL (Swedish Turbine Ab Ljungström) had one of it’s biggest factories, maybe headquarter?, in small city FinspĂ„ng, only 21 miles from where i grew up (later STAL-Laval, today owned by Siemens) a man having a summer cabin neighbor to my dad, worked on Stal-Laval most of his life, and he have talked about them free piston engines, they had some experimental stuff saved, that they had been fiddling with and running from time to time.
It really is a small world?
Edit: i remember he told me some about exactly what Kent points out: enormous losses in efficiency when compressed air is used for powering a turbine/air motor.
It is definitely AI along with some bs. There are some companies still working on them. Toyota’s R&D, and Aquarius Engines Technology along with a few others. They don’t create rotational power so they are being looked at using a genhead based on a linear motor. They are using essentially an air compression chamber on them for the recoil, and I am sure they have issues with the seals and blow by.
Expert forums, the internet, “artificial intelligence”,
 all this technology of “knowledge” can be dangerous and misleading, but it can also be very useful, in this mass of data, select and use those that are useful for your projects,
 there is a proverb for when someone has given a long speech,
 “in through one ear, out through the other”
 :grin:
It is pretty much like any communication throughout history. It is just faster at it. I think ‘garbage in, garbage out’ is pretty appropriate with it. Where AI really excels is not the crap we see on youtube but specific purposes where they can fine tune the dataset and have the selective questions and sometimes it pops out answers no one would have ever thought of and actually work.
Yes it is. Mostly thermal, if it gets bigger (powerplant size) it can beat a ICE. For personal use not.
My e-mail carrier is Yahoo. In the last 6-8 months since they went to enhanced AI, I fight with the spell-checker and text-checker not just recommending: but whole words changing and inserting upon me sending. I can’t go back and edit fix!
The same problem for me on the DOW too. At least there I can review what did post up and go back and force a change to actually want I wanted.
Here is a video not just about engine oils; but pointing out that AI is allowing the Liars to Lie and deceive much quicker, and more effectively:
Yeah. Long video. But view through it and learn yes a bit about engine oils, and whole lot about marketing Liars now self proclaiming themselves as “Influencers”.
“Figures (numbers) don’t lie. But Liars figure (scheme).” “Made you look!” Made you stop what you were doing; could have been doing . . . to put view pennies become dollars into their accounts.
I am not laughing.
youtube and facebook are cracking down on AI generated content. Even with normal youtube channels misinformation exists, which then gets sucked into the AI algorithm and spit back out as information. And always bias exists whether political, monetary, etc. there are very few opinions that aren’t bias, which is what science should be doing but even I get skeptical of some research as confirmation bias exists, and science only studies what they have money for. Which leaves room for say home remedies, that may work, but have never been studied because there wasn’t enough money in it.
for yahoo.
To turn off AI in Yahoo Mail, go to Settings > AI features and disable the Message summaries toggle on the desktop, or tap your profile icon > Settings > Summaries and turn off the toggle in the mobile app. You can also disable Dynamic message by going to Settings > Viewing email on the desktop.
On the web
  1. Click the More options icon (three lines) and select Settings.
  • Click AI features on the left.
  • Use the Message summaries toggle to turn AI summaries on or off.
  • To turn off Dynamic message, go to Settings > Viewing email and toggle Dynamic message off, then click Save.
On the mobile app
  1. Tap your profile icon.
  2. Tap Settings.
  3. Scroll down and tap Summaries.
  4. Toggle the AI-powered summary preferences on or off.
  5. Restart the app if prompted.
