Using any waste oil in my water/steam coil works as a charm… it also reduces the core temperature if needed.
Long time ago they used a device to make so called “carbureted water gas”. mixing the fumes from hot oil with the gas from the gasifier. Not sure if that could be done with old engine oil …
I must try the oil in my plastic waste set up :-p afraid it will blow the lid off …
