We (George Adams and Pete Stanaitis) just got this grain cleaner:
http://www.tractorhouse.com/listingsdetail/detail.aspx?OHID=6977227
Well, not THAT one, but one just like it.
The machine works very well for sorting/cleaning wood chips, The front screen (closest to the input funnel) has 1/4" squares hardware cloth and the rear section (Now) has 1/2" square hardware cloth in it.
The first stage is a cone of hardware cloth inside the front screen. This cone has 3/4" squares hardware cloth. The job of this section is to sort away the largest, coarsest material. It does a great job of doing that. This large material falls out the center of the machine. The “fines” fall out anywhere from the front to about 6" from the tail end.
The good stuff falls out the very end of the drum.
So— the range of chips that we get out the far end of the machine is between 1/2" square+ and 3/4" square-.
We can change the hardware cloth in any of the 3 sections without too much trouble.
Our questions:
- Do any of you use a grain cleaner like this, and if so, what size chips do you shoot for and what size screens do you use?
- Regardless of how you get your chips ready, what size range do you use.
