Here, Steve: http://youtu.be/R4RAxluEMx4
It’s only 1:24 long. Shows rotating truck rim, similar to Wayne’s chunker.
Or here Steve.
Hey ChrisKY and DonM THANKS!!
Don your picture showed me it was worth downloading.
Chris your shortened broadcast link worked fine and with further de-res-ing I was able to view in only 12 minutes.
PierreG i am really, really impressed by this. Sweet and simple. No waste.
James here, I got my chunker running today, not as fast as Wayne’s but I think mine will handle wider stuff. Seems to be working fine. I am gonna use it for firewood too. I will make a different blade to cut up chunks for gasifiers that will split the wood also. Check out this video of the chunker on youtube.
WOW! what a beast! Good to hear from you James.
HEY JAMES, GOOD TO SEE IT WORKING , I HAVE NOT TOUCHED MINE FOE SEVERAL MONTHS, NOW THAT I SEE YOURS WORKING IT WILL MOTIVATE ME TO GET MINE FINISHED
Hi David; Just thought you might like to see my chunker.After seeing waynes and other axle chunkers i built one. I used a rim like keith did for the cutter, but i’m using oak and had trouble cutting and was bending the rim. After many modifications i have a working chunker that will do up to 3" oak although i plan on using 1"-2" chunks.Also wanted to cut dry branches which are harder to cut. Anyways,If you would like to see ,you can watch a series of my ups and downs as i took my journey.Go to Youtube and type in docdcox. Good luck! Dan
Hey James,
Hydraulics is strong enough to move the world out of its orbit if you could brace off from the moon or mars.
