I reached into my deep pocket and did find an easy way to compare your gasifiers.
1:- determinate an amount of work to be performed; example: pumping 5000 liters of water to an height of 10 meters
2:- Calculate the energy needed to do that job, ( E=MGH ) E=50009,810 = 490.000 Joule
3: use 1 engine-piston-pump setup to perform the job
4: run the test on gasoline first, track the time and the amount water pumped in given time
5: check the exact amount of fuel used , compare that with the calculated value, this lead you to the engine efficiency on gasoline.
6: the consumed gasoline wil give the value- energy consumption
7: the equation energy consumed / time gives the power produced
8: try different types of gasoline, different settings untill you have the best setting
9: repeat the test with the best performance at least 3 times ( or just with 1 setting )
10: take the best 3 out of 4 and calculate the average
Now connect your gasifier and do the test with an measured amount of fuel.
start at point 4.
After test and evaluation, decide if your system is performing well.
Compare with your fellow builders and analyze what to do and how to do it
Chair your experiences.
If wood gas and or gasifying can beat the efficiency from gasoline or any other given fuel, then sky is the limit…
To the critics, i developed this test years ago, to proof the claims from the manufacturer, in equipment also currently in use with military forces USA.
To the believers, this is an valid , objective way to produce SSS numbers, ( Simple, Sound and Solid)
To al the builders and users of gasifiers, you are doing a great job
To the people who did al the pioneering and testing new system, my utmost respect.
To the wannabee’s and just talkers, stop talking, build it, gasify it and just do it ( was from Nike or from WK, not sure about that.)
