Sorry, I didn’t realise. Go to (2.5.2 Design…) Anyway, that’s the one I commented on.
This year’s tally is 5 face cords of hardwood; mostly maple, and 2 face cords of softwood mostly pine… based on passed years that will be enough for even a hard winter.
Hey David. I also always plan for a hard winter just in case. Are you having to brush your chimney during the winter to counteract the use of pine?
No not really, I use the softwood for a fast hot fire in the mornings. I do sweep the chimney every fall but never get anything but flakey light stuff. It’s those smoldering fires that cause all the problems that and wet wood I think.
Early morning wood consumption calculations:
During the past mounth I burned
2000 pounds for heating/hot water/cocking
Saving 150$
200 pounds for driving
Saving 150$
Conclution: I’d better do some more driving
BBB
Good morning JO.
Years ago I paid for my farm selling wood at $27 a cord ( 5700 pounds ) delivered to the mill 15 miles away.
Now days I use that cord of wood to put my truck down the road a LONG WAY !!![]()
BBB
Hi mr. Wayne
What is the price of firewood now over the pond? Here a cord (4m3) of beech is sold for about 250$ and oak for 200$.
Hello Kristijan.
I think a cord of oak wood cut into firewood lengths and dried would sell for about $200 if you could find a buyer . Very few people in my area heat with wood anymore .
The wood I mention above was poor quality and not fit for saw timber . Hauled in tree lengths and green . Back in the late 80s and early 90s I was glade to get the $27 a cord. I think now the same wood sells for about $50.
Cheaper than a membership at a fitness club is cutting wood chunks
I cringe a little as I cut up this kiln dried wood but it was free for the taking from a construction site dumpster. Got a 3000 lb load this summer and have been converting it into fuel sized pieces
The 90 lb 6" X 8" timber is cut into 3" lengths then hand split into 2" chunks
Where there’s a will, there’s a way. Love to see the waste become the waste not.
Got my blade(s) mounted on my axle. Just need to sharpen/shape the blade, find a sturdy-enough frame/anvil, and get my old riding mower engine going again.
Looking good
Were those blades originally a diamond saw?
Looking great, how are you going to mount the two blades together? Will you cut the “snail” shape and weld the edges tigether?
My plan was to cut one blade with a snail a bit small, then use it to cut a slightly bigger snail in the other disc (my plasma cutter tip is 1/2 inch from the edges of the “standoff” so the second snail will be a 1/2 inch bigger if I trace around the first snail.) This would give a 2-bevel edge, similar to the fancy Fiskars splitting axes, which I’m hoping will cause the chunks to split themselves with the grain as it’s being cut.
I’m curious, could I use my mild-steel MIG welder to join those discs near the second bevel/edge?
I also have a smaller piece of 1/4 inch steel plate that I’m going to bolt to the outside surface to help with rigidity and act like a “washer” for the bolts.
I got them from the scrap pile of an equipment rental place. I think they’re made to cut concrete like these…
Great idea!
As for welding, you risk makeing the blades brittle.
I usualy go with inox electrodes when welding hard steel. I dont know why but they seem to heat the material less. Allso l weld every material of less thain 2mm thicknes with inox. It tends to mske less burnholes. I am talking about stick welding, l havo no experiance with tig.
Hi Brian, preheat, and post heat is how I have always welded hardened steel. I have welded lots of leaf springs this way. If you don’t have a oxy-acet. torch you could use mapp gas, or forge to heat to a dull red, weld then heat to dull red after weld. Let it cool slowly no water. Al
I have found that I can reshape not and reset the teeth on the bandsaw blades
I have been using 3/4" wide by 3 TPI blades and using a thin cutoff wheel on a 4 1/2" grinder just touch the back of each tooth to sharpen
Then clamp the blade in a vice and using a small pin punch and hammer , tap the teeth to reset them
Takes about 20 min and the blade cuts better than new
Something to consider for wood storage, and drying, https://www.youtube.com/watch?v=_NEyzjnONQI
That’s pretty impressive! I wonder how much they cost, before and after shipping. I might be visiting family in Finland this spring; maybe I can stash a few in my suitcase on the way back…
