The Longest 100 Miles, 1967 movie featuring a woodgas bus. It’s on Youtube now.
I think they have a TLUD gasifier. Draw your own conclusions as to accuracy, but, since hollywood movies about woodgas are rare, I thought you might be interested.
Part 1
Part 2
Best scenes showing the system:
Part 1
16:09 Priest offers the bus
18:10-18:45 coconuts
19:05 Install engine
19:50 Parts begin to arrive
29:45 Making charcoal?
30:05 Assembly begins
38:10 Loading fuel
38:50 lighting up
Whoops! View of the engine when running with no visible sign of
woodgas coming in to carb. Let’s hope it comes in below carb?
41:40 Engine start
Part 2
00:05 on the road, running on woodgas (coconut husk or hull charcoal?
00:56, 2:16, 2:23, 3:58, 41:42, 46:30
David S is working on his ash dump door. He had his grate held up in place by a spring and it must have got too hot and lost it’s temper and sagged. I suggested just using a piece of pipe in it’s place. Hope he gets it all rebuilt soon. I call him up and bug him from time to time. I had a backfire when I got home last night and it blew the pipe out of my mixer. Had to put new duct tape on it … Regards, Mike LaRosa
Peter,
Keep forgetting to respond to this last comment. I am not shy just extremely busy this time of year with my business. I have the gasifier torn down right now to modify the ash dump door. I have it partly done. I also probably need to change my grate from the rotating style I was trying to use to something else. The spring didn’t take the heat, and it was the key to keeping my seal seated. I will more than likely switch to the wobble motor concept. I didn’t know how I would make that work with the shallow ash pan I have, but today I got an idea from a fellow wood gasser that called. So that is where I am at. Not sure what else you would want to see on my little truck. Yours pretty much would have mine beat at any “artistic” show! ;o) !!!
David S
