Woodgas generator as part of an off-grid system - random thoughts and pictures
good day ))
a couple years ago this members of this forum provided great help in building my wood gasifier.
now i would like to share my experience running it to power my household in winter months.
this will be incoherent thread - just some unrelated bits of information
lets start with cleaning routine
hay filter - grey Mobil drum fits nicely in slightly wider Agip drum
bottom part with rubber floor mat as gasket
top part upside down
it usually takes half of a hay bale to refill the filter
usually i leave a layer of coal/ash on the bottom of gasifier for heat insulation
cleaning soot from heat exchanger. silicone rubber used for gasket - it is little too hot for regular rubber there, it hardens over time.
tool for pipe cleaning
stuff that comes out of heat exchanger
most unpleasant part is where soot meets condensate - the cooler
yuck!
preparing chunks ))
stage 1
stage 2
one bucket weighs in around 3.5…4 kg and lasts approximately for an hour.
hopper contains three buckets when fuel is completely burned out,
but usually i load two buckets when refill hopper at running engine.
I like your plastic jug storage drawers.
Don, I was about to make the same comment, but decided to wait until you did :smile:
I have been heating my house with wood since I finished building it 25 years ago, long before I was involved with wood gas. The firebox and the piping is all encapsulated in stone and concrete so no way to alter any of it, but how many times have I looked at that fire in there and wished I had a way to get more use out of all that energy in the fire.
Very good report and picture sets AndrisL.
Wood making electrical watts energy.
Any wanting to see his thoughts, design evolution and engine generator this is covered much across five topics.
You can find and read these by first clicking open his avatar icon of “Animals. Drive Very Slowly”.
This will bring up a summery box on Andris.
In this box again click on his larger picture icon.
That will bring up a complete page of his DOW activities.
There click open his “Topics started”.
Select and read.
It might be better then you think the rocks are heatsinks like the mass heaters.
You can get fireplace inserts with blowers and such that are far more efficient for combustion.
fireplaces can be replaced it is just costly. :slight_smile:
thank you Steve ))
i think i will add those links to my other threads in the first post if i can still edit it.
as for running the generator - even without any automatic, such as timer for grate shaking or auto gas mixing - the generator does not require constant babysitting. if everything goes right, it can run for an hour without any intervention.
of course it would be nice to have automation for increased power output and fuel efficiency.
usualy i sit home and monitor charging current using bluetooth BMS application.
if amps decrease, i go to workshop and see what is going on.
Looking good Andris, JK bms?
yes, it is jikong
200A, 1A balancing current.
works good, except for a intermittent current sensor issue, it usually happens at simultaneous large and nearly equal charge and discharge currents.
nothing serious, but annoying because it spams log, replacing important messages.
a little video with newly installed digital wattmeter.
it measures DC, because generator is connected to MPPT input of a chargeverter.
analog ammeter measures rotor magnetizing current.
current can be adjusted with constant current setting on DC booster (blue pot).
usually it is between 9 to 12 amperes at 12 to 15 volts.
interesting fact is that magnet current drops as the alternator warms up and coil resistance increases.
I got bad results via solar mppt inverter. Had to ad some loads and lost half in resistance. Does it work for you?
i have 3 phase alternator, 220 volts between phases,
that results in approximately 320 volt open circuit DC.
it is much better now with hybrid charger/inverter with 500 volt MPPT,
working voltage is 200…240 at 2000…2400 RPM and output power over 3kw.
but when i did use 160…180 volt MPPT chargers previous winter, i had problems
with MPPT putting too much load on engine, not allowing it to operate at optimal RPM.
their operating voltage was around 120 volts at 1700…2000 RPM, output around 2kw.
first i put a big rheostat in series and lost some power in heat,
but better solution was to limit rotor magnetizing current.
