Got some time for the tractor.
Starting build the condensate collector for the cooler, my pile of stainless is on a critically low level, so a old cng-tank will do.
Testing in place, the “in” and “out” pipes for the cooler is visible. The tank is divided by a stainless sheet, in the way the cold side is 1/4 of the volume.
This is the hot side, the gas inlet pipe is protruding some, in the way the incoming gas hits the water level, to draw some extra water up the cooler, to help the cooling effect.
This is the cold side, where incoming (from cooler) protrudes some, to direct water droplets to be thrown to the bottom.
Things getting in place. Splashed some paint on it.
The cooler.
