Tone, do not get me wrong. I love both wood and charcoal gasification, they both have their applications and they both can be more efficiant with one application over a nother. None is worse or better thain the other in specific circumstances.
This sayd, plese forgive me to share my wiews on the subject you described.
Yes, wood does start to pyrolise at a lower temperature. But we may split this pyrolisis products in 3 parts. Lets call the first one the endothermic ones, (H2O, CO2) and the second ones exothermic ones (methanol, acetic acid, tars, methane⌠), and the third is just carbon (charcoal).
There is always an exess of water in wood wich shuld ne dealed with, boiled off, then condensed, this requires energy.
Then we have the reaction of newly formed charcoal with the rest of the water and all the CO2 produced, (wich can be up to 50%vol in pyrolisis gas!). This is just the same as a charcoal gasifier.
Then we have the âexothermic productsâ. They do crack some in the glow zone but the vast majority will meet the air on the nozzles and oxidise, burn in to basic components CO2 and H2O plus heat, what happens to them is whats in one paragraph above.
When those âexothermic productsâ do crack (down to methane) they will always produce soot. In other words, a soot making gasifier will make more methane and vice versa. You have prooven that yours does make almost no soot, wich is no surprice as you introduce oxigen 3 times, wich can only mean that those pyrolisis gas products burn completely down to CO2 and Water, wich then âcracksâ down to CO and H2.
So, in short, unfortunaly a good tar free wood gasifier will only produce about 5% methane, tests show. Not enaugh to realy make a difference.
All in all it all comes down to the carbon to water ratio. To much water, the high heat capacity steam robs the gasifier of energy. Too litle, gasifier starts producing poor gas, as you have shown with your tractor. The perfect amount is hard to hit, and every wood gasifier has a sweetspot where it runs best, some with hopper half full, some near empty⌠this is whats hapening.
But with charcoal, you got controll Thats a big plus for me. It is possible to âprogramâ and adjust your performance perfectly.
