i’ll see if i can find more
Thanks Arvid
So there is no taper inside as with a conventional cyclone ?
Thanks Patrick
Here is a daytime video walk around of the tractor. The ignition stayed on so the battery was dead… Next time startup
yes you are correct, no taper. you still need an exit at the bottom and a reservoir for what collects. I believe on my 1 1/2 inch in and out it was 2 inch at the bottom.
typically on a 1 d 3 d the length is 3 x the tube ID. having it shorter will give you a higher pressure drop across the cyclone than having it longer. At least that is what Stephen has found in testing.
Hi Arvid
That is so much easier to construct !!!
I will have to try one to see if it is as effective at Stephen makes it look.
But I have found that the carbon soot is so fine that it just does not get separated In a conventional cyclone.
When I empty the soot into a bucket is so light that if you drag your finger through the soot there is no feeling or resistance on you finger!
But will give it a go !
Thanks Patrick
Went to the Wilberforce Agricultural fair today. Lots of interest and after a friend (thanks Wyatt) cleaned and adjusted my points I had my best run yet of 95 minutes of run time at a high idle running on softwood charcoal. Went to refill and it had burned 6 gallons of charcoal…
video here:
and some stills for the dial up crowd
A great day…
Nice looking and running machine.
Thanks for the video and pictures Mr.Dave
Looks like you got it going your way !!
Thanks Wayne,
A little paint changes the look a lot…
Sounds good looks good
real nice!
Nice paint job DavidB
Nice short easy download.
Sounds great.
Well one of the problems with the tractor is: I need to process more charcoal!!!
Some pics of the grinder… Early days
Is that plywood used as spacers between the blades?
Hi Bill, yes there are 3 inch cutout pieces between each blade. The large square pieces are 2 of the sides of the box to be.
My mom came to visit and she is a real photographer. Here are a few quick shots; nothing new but the light was great…
Very nice pics!
The bottom looks like calendar material.
TerryL
Terry’s right, definitely a great calendar picture. That needs to be submitted somewhere.
I was thinking about you last night. Tore more boards off the old barn and had a big fire. I worked the pile down to where I had about 100 gal. of good glowing char that could have been shoveled into a couple barrels. I have 3 barrels already and no use for it YET. So they burned to ash by this am.
Hey David ,
I’m with the guys above . The picture needs to be hanging on the wall !
BBB
