I would guess it has a low voltage winding, maybe around 10 amps, 20 if you’re lucky
He uses a Kill A Watt meter, or something very similar. If +/- 1Hz is good enough, then it’s a simple solution, and really useful for lots of measurements.
edit: Checked the video, and it is a Kill A Watt meter, and it reads to a 0.1Hz. That ought to do it. Though a permanently installed freq meter would not be in the way.
RindertW. the DC-out charging capabilty is from a small set of separately wound coils. That rough AC generated is then ran through just a small bridge set of diodes. VERY low wattage. 120 watts, usually at the most. And the DC out voltage is relatively dirty and NOT voltage regulated. Should only be used to charge up small, thick plate small engine starter batteries. For real, faster, battery safer, four-step-voltage capable battery charging use a good separate dedicated charger from one of the much higher wattage outlet ports.
Disposing of contaminated gasoline?
Depends how much gasoline you need to get rid of.
Depends greatly on where you live; your household mates; your neighbors.
Depends on whether you strictly want to abide by your areas current evolved legalities.
Last time over 20 years ago now in professional Urban area shops it was then $10 a gallon to have pick up for disposal. And someone had to sign their signature on the head of the recorded chain of custody tracking. Go cheap on the contractor; and it got ditch dumped; and it would track back to you the originator, signer.
I expect that price now will be double, triple now.
True Rural living we would store it and at an annual woody debris bonfires time pour it over the pile a day or so ahead of time. Wait for the majority of the volatiles to evaporated off and then in Early Cool of the Morning FROM A DISTANCE lite off the burn pile.
Other ways too. Most not exactly legal. The rule of the three iLL’s applies here.
James Cordon did say he would wait for the majority of settling separation, then burn it up the least contaminated portion in an IC engine. Your older generator would be the candidate for that.
Just please don’t dump it directly onto the ground. Irresponsible.
My TLUD, for charcoal making, seems to burn wood tar with almost zero smell. And my neighbors are used to me making charcoal. I think I’ll try soaking some wood chunks in the nasty stuff and then put them in the TLUD. Hard for me to crud up an engine even if real old.
When I was doing ironwork it was common practice in the winter to fill half of a 5 gallon metal bucket with gasoline and then light it as a source of warm up heat. Surely things could have gone wrong but I never heard of anyone getting burned from the practice. If diesel was on hand we would use that the same way.
I love old gas. I mix it with biodiesel and used crankcase oil, and spray it on the fence line. Slash and burn agriculture. I tried the weed eater but I spent 5 minutes wrapping the string on it for 15 seconds of whacking. The goldenrod/burdock/tagelders/raspberries/tansy were too tough for the weed eater.
Yay! Chemistry!
I wouldn’t want to start an ecological brouhaha but there are microbes that quickly go to work on petroleum spills. I’d prefer working with them than spraying glyphosate. I have the same vegetation you listed Bruce. I got a couple circular blades for my weed wacker to work on it but it’s still slow going since everything is grown chest high now. The burdock is probably even harder to cut than the raspberry vines. I decided to wait until fall and let the frost do it’s work.
There is nothing left but charcoal and ash. It’s similar to the propane weed burners. I am sorry if I misled you. I use the old gas to burn the weeds. I don’t poison them.
I don’t have anything here that would poison plants.
Nope. Not in the US. Liability. plus gas evaporation isn’t controlled which probably violates some epa regulation aka the gas cans.
Stihl’s have the plastic blades that can go through most of that. up to probably 3/8" of soft woody material. (it also cuts through with ease plastic edging, small wires, etc.) They also have essentially a woodsaw blade for even thicker stuff, which works great for up to about 1.5". it mows 1/2" it down like a string trimmer with grass, however, it doesn’t work well with grass.
The ‘organic’ mixtures tend to include clove oil and peppermint oil, but like the torch, they just burn down the tops so grasses and stuff will grow back from the roots.
