Small or home made sawmills
I didn’t have anything that really needed cut but set up the sawmill for pictures. Sorry for such a long post but hopefully it interests someone.
This is one of the log clamps. I added the angle iron and the threaded rod.
This is a short birch log clamped in place. This one is only around 14 inch diameter and 28 inches long. Being able to saw shorter logs means I can saw things that most sawmills wouldn’t bother with but there’s a lot of projects that don’t need long boards and this short log would normally just be firewood.
My mill claims it can saw a 21 inch diameter log but the clamps won’t open that far.
You have to nail or screw these angles on the ends until it gets small enough to clamp.
This is how I have the water drip set up for cooling/lubricating the blade.
This is ready for the first slab cut.
Not much there but could probably get a 4 inch wide board.
Now comes the decision. Do I flip it or keep cutting? There’s some defects that look pretty deep.
Took one more cut and hit a couple soft spots.
This is where the extra threaded rod comes in. The original clamp would twist the log out of square.
A few thin slab cuts to get a flat edge.
Now the log can rest on the stop of the carriage. 10-1/2 inches won’t quite get rid of the live edge but should get close.
There’s one of the defects but might be a 16 inch long 1x6 in here.
Nope, more defects. Maybe a 1x4. Time to flip it again.
Kept cutting until..
The lower board looks like a good charcoal board. Too many defects.
Time to flip it one more time.
Now time to edge.
These two have some defects but looks like about 6-1/2 inches should be good. I use a 2x4 on the carriage stops to give it a little more height to keep them straight.
This is an old rough cut 4x4 again to keep the boards straight to edge. The original clamps aren’t perfect.
Finished. Just random sizes but not bad considering it was basically firewood.
These should plane to 3/4 inch thick. I cut at 1 inch but I didn’t take into consideration the blade thickness lost at each cut.
My scale does have marks for 4 quarter, 5 quarter, 6 quarter, and 8 quarter that will give me full size boards but I’ve found it easier to just accept the lose since they still clean up at 3/4" if I cut every inch. My final cut can only go to 1" but, in this case, that board was junk so just got tossed into the slab pile as either firewood or charcoal.
