Good eye Bob. I thought something didn’t look quite right but didn’t know it was the cooling tubes until you posted it.
Garry C
Garry C
I see no cooling tubes for the hopper either,are the cooling tubes seperate from the hopper, or this was an earlyer design- Get it working down the ROAD.
Thanks Wayne, probably a cold wood storage tank and well-cooled steam in the condensation zone prevents a large expansion of the gases, as is happening in my case, well, for such a system I have to provide a discharge valve and a burner tube in which the gases will burn intimately after stopping
Good morning Mr. Bob .
That particular video is 12 years old and was before I started using the hopper cooling tubes . This is a 93 dakota . It looks much like the 95 dakota that I am now driving .
Edit .
I have gasified two 93 dakotas .
Here is a very short video of number two 93 dakota .
Yup you are the WK Gasifier King of the USA, on the number of gasifier builds. You have gasified some 15 Vehicles including a tractor now? All since 2008. This has all been done from using simple tools and in no fancy shop. Just using recycled scrap and junk. By using good fabricating and welding skills, with this continue mind set of making it better modifcations. Until you can now say, Quote: “on my present gasifier build I can’t think of anything I would change”. This is success in my book. Thank you for showing us how like, like all the others in the past and present, the how toos of gasification.
Thanks much for the comment Mr. Bob but now you have gotten my head swelling so that my hat will not fit ![]()
Wayne, we all know here on this site you are a very humble man in the things you do. So your hat will always fit fine on your head.
Yes it is amazing how well COWBOY KEITH set us up with wood gasification system’s that work as good as Wayne’s last speed test vidio- Plenti of power on wood–A lot of testing and trial designs/studying patients. To get a wood gasifier as good as the HAVE_WOOD_WILL TRAVEL- Book. He saved us a lot of gess work and build tar gas fails,or weak gas fails.
Hey Tone .
You were asking about shutting down the gasifier in a parking lot or public area so I made this short video for you this afternoon.
If I haven’t been pulling the gasifier hard I pretty much just turn the key off.
@Wayne , do you close off the wood gas mixer valves and your intake tennis ball valve when you shut down?
Garry C
Garry ,
If I were shutting down for the night I would try to remember to shut the air mix dampers off to kill the fire quicker . If shutting down for shorter links of time I may leave them open so the fire would more likely stay alive .
On this particular truck I don’t have an air intake tennis ball valve . I do have a one way check / flapper valve to keep the air flow from reversing and smoking at shut down. It is a cheap plastic valve that can easily be seen in the videos on this thread post 978. You can see it going into the dropbox / heatX housing .
Thank you Mr. Wayne, it feels good to have a friend on that side of the pond
Hello Kevin .
We were cluttering up Neils thread so I thought I would skip over here to try to answer your question about over looked issues with a gasifier system.
Good morning Kevin
I think not having the proper job or tasks for the gasified machine.
Don said it well when he mentioned he only drove 3 miles to work and it was not worth the effort to fire up for that short distance.
I have another example of my farm tractor and why I removed the gasifier from it. ( but still have it handy )
In the winter the tractors job or duty is to drive into a hay barn with tons of bone dry hay, spear a roll of hay and set out to the cattle . This takes from 10 to 30 minutes and the machine is not used again until the next day .
The amount of gasoline I would have saved is not worth the time or very small risk of fire .
In the summer the tractor job is working in the hay field with dry hay sometimes knee deep. Also when working in the hay always in a big hurry trying to take advantage of the suitable weather. Usually it will be my wife or son operating the tractor while I use another .( the operator knowledge is more important than the machine )
A job the gasified tractor is very good at is bushoging pasture land in the summer ( I have several videos of this , Wayne’s 444 International thread ) The problem with this is I also have a big bat wing bushog that covers 4X the ground and with the wings I am able to cut ditch banks and cut under low hanging limbs . I can save 3-4 days of work using the big rig .
One other example of gasification not fitting a task is my electric power needs . My electric power cost is less than $2 a day or average 8 cents per hour. In 30 years the power has been out about 5 -10 hours . No way I can justify gasifying my electric power to compete with the above.
With my farming duties I use a powerful and heavy work truck daily and usually not in any big hurry. The big problem with this vehicle is it only will travel about 6 miles on a gallon of gasoline . I consider this to be a very good application of gasification . ![]()
All the above is based on availability of gasoline at a moderate price . If gasoline becomes scarce or if prices get too high the rules will change
Have Wood Will Travel
I feel the same Wayne. I don’t need to go to a lot of effort to run a gasified gen set for power but when I do it’s so I can keep learning the ins and outs of the systems and ways to improve the infrastructure and my abilities. If I was never in a position that I needed to make my own power that’s fine with me but the idea that I may have to go without is completely unacceptable. We drive less than a hundred miles a month. No real need for a gasified vehicle but watching the videos and reading you guys tales makes me want to do it just because it seems like fun. Maybe this year.
That is in large part why I do it. I still like fun!
Yes Steve .
You can understand at $2.00 USD per day why I am not making electricity with gasification .
Thanks WAYNE KEITH for the reply on few paragraphs back, greatly Defined-with a farm to run and wood to chunk- that would eat up most days time in itself- I can see how solar would be too long to pay back at that rate-my light bill last 19 years under70 bucks a month unless i am welding alot out in the gardge.lakley its been just over 100.00 bucks last three months.
I TOLTALY AGREE ON ALL ABOVE being not worth the effort, my 3500 chevy gets about 8 mpg empty.THOUGH i dont use the truck enough too gasify it.not that many heavy loads to move around as your farm duties v10 truck has too haul.
We are at 4 bucks a day as well. Electric dryer and hot water heater account for a lot of that. Fan on the wood heater and pumps running 12 hr a day. Well pump All LED lights including the grow lights that run 16 hours a day from Feb to May. Supplemental in the greenhouse for 6 hours a day during growing season. Dish washer heating water and sanitizing. Only gas appliance is kitchen range. Getting off-grid would be really hard for us but we are adaptable.
Mr Wayne, my philosophy is (or was) the same. My electric bill is even smaller thain yours, rarely exceeding 30 dolars a month. A few led lights and one fridge with a occasional welding dont justify any home generation investment.
But! The other day we were without power for over 2 days. I had to borrow a gasoline generator and l felt like a moron. I only burnt maybe a gallon of gas but still, they say a blacksmiths horse is always barefoot and l realised l dont have even one mean of generating my own electricity and this has to change.
