What the hay bailer chunker
Hi mike , those look closer than i got, have you seen any electric motor companys that sell them serpentine pulleys with the set screw bolts too hold the pulley on tight too the keyway. if there is any i havent found them. Thanks. Probley if one of them alternator pulleys slid on tight, i could tack a washer or nut on the shaft too keep the pulley from sliding off the shaft.? And i have fiberglass rosin too glue it on shaft first.?
