ok, i check and change
Video’s should now be visible
Thanks very much Koen . Looks like you have the bull by the horns
I will keep you and the doctors in my prayers for a safe removel of the tumor and complete healing to good health in your body. For Yehovah’s name sake in and by his words Name Yesuha.
Thanks for the update.
Congradulation KOEN on your bambo gasifier, it looks allmost like it is charco burn,Clean flare,. May the lord be with you at your surgery, In jesus name i prayers for you healthfull recovery.
Koen,
Hope this finds you well and recovering!
I have watched your excellent videos. Is there any possibility outside air is getting into the gasifier before (or even after) the nozzles? It seems to me the flare is burning too well (inside the exit / output) after you taped the secondary air intake of the flare “mixer”. Also would help explain the weakening of gas when the very substantial industrial blower is ramped to high speed. I can imagine that unit can generate quite a vacuum and would find “leaks” not readily apparent. Forgive me if this is foolish advice!
Hi Mike,
Good observation !!!
Indeed there might be airleaks downstream after the nozzles.
That is now next on the schedule to install few mods/enhancements.
The other thing for flaring is the gas speed at flare nozzle. I have to build a bigger one ( shower head type) to allow lower gas speeds.
This blower can ramp up to 300 cubic meter / hr
I was running at 100 only…
Disadvantage of using bone dry material is the slower flamespeed hence easy blow away the flame.
But… i got lemons…
How are you doing on the healing up after the operation Koen? Still praying for you. May blessing on you.
Sitting front dr office as we write…
Stiches to be removed and to get the verdict on tissue testing.
Keeping fingers crossed.
Huge scare side my left jaw/ear, but so far all well
Yes Koen ,We hope for a quick healing
Quick update…
Thanks to all good prayers and wishes the outcome is good.
Tumor was not yet morphed into worse, removed entirely, no further treatment needed.
Now only wound healing, some rest and fresh mind for the future…
Thx all
