Guys thanks for the all tbe valuable input. When i was searching for dryers i found about a dessicant dryer that removes mosture with the use of silica pellets hope it works. Any idea or previous experience
I used cyclones with sucsess to extract moisture (fog). Shuld be ideal for your steady gas suply. Its important cyclones are small so that high velocity smashes those water droplets on the wall where it can flow out from the bottom.
Can you give me the dimensions of you cyclone and the gas flow rate. Then i can work out my required size
Thanks alot for the share
Tom the link is not working
this is inside 30 gal barrel with wash tub on top of 10 gal can . collected one gallon . I need to add cooling coil to keep condensate from turning back to steam . condensate overflows washtub and is collected in bottom of 30 gallon barrel
look for use of condensate with raising poultry
It probably won’t work for very long. They will absorb water, but I don’t think they can absorb as much as you will get, and then you will have to dry them out. Chances are pretty high you will also get other things in your condensate so I am unsure whether drying them out will work that well.
