As you can see, I understand very little of what is happening, I hope you help me.
The nozzles.
- Smaller nozzles increase penetration and increase heat, but increase resistance to airflow? Truth
- The oxidation of the carbon provides heat that oxidation the wood above the nozzles? (ash?) Truth
- Upward-facing nozzles provide increased heat in the wood container and earlier oxidation of the wood?
- Oxidation of carbon emits water, gases,air,ash and tar? Truth
- Water, gases and tar are converted in the glowing carbon layer under the nozzles into combustible gases? (ash?) Truth
- The conversion reduce the heat? Truth
- To maintain the heat and change the gas flow, we make a restriction, smaller restriction increases the heat? (or increases the mixture of gases (cracking of tar gases?) Truth
- Does the distance between the constriction and the nozzles affect the heat?
- Smaller distance between constriction and nozzles increases the heat?
Edit
10.If we increase the heat of the air through the nozzles, does the rate of conversion of the gases increase? Truth - Increased heat allows us to increase the distance between restriction and nozzles, more carbon to the conversion of gases while retaining heat?
- If we increase the heat, do the nozzles have to be bigger to maintain the oxygen content?
- If the gas passes through too cold coal, is it converted to CO2 again?
Edit numbers.
Edit Truth
