Homestead Project
Chris when i had my well pump replaced they found high levels of fluorine in my water under the EPA limits but high non the less. I installed a reverse osmosis system to remove it as I don’t like the idea of drinking it. Well the system I installed included an led UV light treatment to kill bacteria and it also puts back the minerals people need in their drinking water. It runs off the line pressure in the house and just draws 6 watts for the led light off a wall outlet. I bought an expensive unit because it has the lower 1:1 drain to filtered water ratio. You can pick then up online or at your local hardware store.
I was actually surprised there was a filter system which replaced the minerals you need to get from water after filtering. The system is about $450 with $75 of annual filter replacement. I can tell you my coffee is less bitter now. Anyway I just figured you might find it interesting. I didn’t think reverse osmosis would be cost effective before I looked into it. After seeing the cost I decided it was worth it to know my water was safe even though it originally passed the EPA test unfiltered.
