My first small engine run
It’s been my experience that most of the ones I’ve used have one inch of insulation. OD 20 inches tank size 18 inches . Your mileage may vary
You can poke a nail into the insulation to find the thickness, then subtract that from the overall diameter.
Yep the 18 inch dia tanks are usually the shorter 40-50 gallon ones.
Hey All,
My wife picked up a some goodies for me at a local auction. The first item is a medium size squirrel cage fan I can use for drying fuel or moving air around. Five bucks and it runs well, just needs some minor housing bracing work, cleanup and paint.
This baby puts out a lot of air for its size.
This unit had one slightly bent fan blade and scraped when turned. No one bid on it and my wife got it for a buck, $1.00. Can you believe it! I took the cover off, used a pair of vice grips, tweaked the offending fan blade and it runs great, no vibration at all.
I’ve never seen a motor so adaptable to cycles and voltage.
The inlet is 3 1/4" and the OD is 13 1/4".
The fan has a 7 1/2" diameter and the ID is 11 1/2". Note the balancing weight attached to the top blade, quality unit. The outlet is 2 3/4". I’ll make a gasket for it, fabricate an inlet cone and give it a try. I really hate attaching anything to such a nice antique.
Pepe
Good wife! But guilty of aiding and abetting your habit.
That forge blower looks really bulky. I just don’t know how you’ll store it. I do happen to have plenty of space next to my homemade forge and I wouldn’t mind keeping it safe for you. :wink:
Too bad UPS doesn’t take bulky stuff, drats. Here’s another really bulky one, same size, but powered by armstrong. Price was armstrong, too. My wife gave a C note for this one at the auction, someone else wanted it, too. Drats.
Pepe
I really like the forge blower.
Hey All,
we’re going to be sunny and almost 50 this Sat and Sun. I’ll probably burn some wood before I retire my unit for the winter for teardown and further mods. One of the mods will be heat gathering shroud over the 3 hottest cooling pipes on my cooler. They are all in one row simplifying the duct construction (basically a rectangle). The harder part will be connecting the 2. Here’s a view from the front of the unit.
Here’s a link to the site I use for titles, etc.
http://wigflip.com/roflbot
Pepe
What is “spai” over on the right side of the picture? O.o
Hi Brian,
SPAI is a single port air inlet on the circular manifold enclosing the tubes to the nozzles. This unit was a fluidyne design (third pic) before I started modifying for the better. This is the point where my experiences and reading finally began to come together, namely “preheating incoming air” by putting the air inlet tubes in the hot exhaust gas stream. It works and was well worth the effort. (last pic.
Pepe
<img src="/uploads/default/original/2X/f/f48ee861b76deb1afa9b089cda61ff3736a6569b.JPG" width=“666” height="500>
This is the last pic for the above post, don’t know why it didn’t post above.
Pepe
Hey Everybody,
Refer to the chart on comment 411, August 18, 2015 @ 5:22pm. When I find my hard copy, I’ll post it here.
I took a few minutes to analyze my temperature readings from 5 places on my gasifier.
  1. The PREHEAT temp peaked @235*F @ 9pm. It stayed fairly constant to the end.
    There’s a reason for this that I finally recognize after all this watching and reading.
    I’ll get to it after I tell you the other temps.
  2. The BURNER OUTLET temp peaked @ 600F @8:45pm, cooled on & off 20-35F, but
    remained fairly constant to the end. There’s a reason for this.
  3. The CYCLONE OUTLET temp peaked @380F @ 9:00pm and only cooled 30F in the
    rest of the run. There’s a reason for this.
  4. The COOLER OUTLET temp peaked @ 175F @ 9:00pm and only dropped 25F in the
    next 45 minutes. There’s a reason for this.
  5. The HOPPER TEMPERATURE was 225F @ 9:pm and remained mostly constant
    almost to the end when it rose to 285
    F.
The next day I opened the hopper and found I had burned down to the restriction. In my head I guess I had burned a half hour or so too long. OK, now do the numbers tell me anything. Yes, another piece of the 75% . Here’s what happened. When the fuel load was consumed down to 4"-6" or so inches above the nozzles, pyrolysis stopped (no wood left to pyrolize) and the charcoal/char bed became the fuel and burned up. The preheat, burner outlet, cyclone and cooler temps stayed constant because to them it was business as usual (heat).
The only real trend I think is the cyclone outlet temp. It peaked @ 9:00pm and steadily declined to the end. I will probably watch for this decline trend and let it run for another half hour. This kinda jives with my half hour too long guess from looking where the burn ended. Darn, I guess I’ll just have to burn some more wood
Pepe
After you bring up the picture use the arrow key on the upper left hand corner. Click once to enlarge, then click again to close the picture. I usually don’t have to use the back arrow key but I chose the wrong capture option from the choices circle. Here’s a link to the site to download Gadwin Print Screen. In the instructions you’ll see a circle with choices on how to capture what you want. This is Gadwin Print Screen 5.4, it’s free.
http://www.gadwin.com/printscreen/
Looks interesting. I hope your pictures get sorted out (literally).
Hi Everyone,
Finally sorted out. Downloaded one at a time in order.
Five minutes with my new battery impact driver and it’s all in pieces. So easy with a little planning and 2 years of struggling, lol!
The mating faces and the gaskets are all good even with some of the hottest temps I’ve recorded.
Loaded and secured on my $25 HD military welding cart, what a garage sale deal! Check out those tires!
This is using a new gasket material Tom C. suggested. Used 1/16" high temp flat gasket smeared on both sides with Flamebuster latex caulk. It’s hard but it sealed great and took the heat. The heat shield extensions were definitely worth the effort. Yes, I’ll have to redo this gasket on each teardown. Gosh, what a chore, I don’t know if I can take anymore! ha,ha. It’s really a pleasure to make changes that work well.
This is the old connection. I moved the gasket to other mating face protected by the extensions. I then cut out the sides leaving just the corners for line up assembly. No more heat trap here to destroy the gasket material.
Left just the corners for assembly line up.
Preheat exhaust connection to SPAI manifold.
Hi All,
Here are some highlights of what I will be doing this winter to improve the performance of my unit. I’m sure some of you are as interested as I am in monitoring the temp at the restriction. There are other spots, too, but this is most interesting to me.
  1. Looking for an alternative to the Fluidyne, I ran across Jim Mason’s AllPowerLabs and the GEK design. Youtube yielded this GEK derivitive posted by Lemonycatapult.
1a. I liked it, but I thought too much plumbing.
1b. I settled on this design I saw posted on youtube. Had I only known then about the importance of preheat. I made it easy to make it hard.
1c. My lines come through the firetube wall via a threaded 90 degree elbow. The nozzle is a 1/2" pipe cap drilled with a 1/4" hole and threaded on to a short nipple which engages the threaded elbow. Next time I would come through the wall with a 1/2" threaded pipe coupling. It would be easier to establish the nozzle ring diameter. I think it would easier to remove items from also.
1d, 2. I will use 1’2" or 5/8" soft roll copper to make a preheat system like this.
  1. One thing I like about the removable hourglass hearth is that I can fashion cones for diff gas/hp rqmts. I have one for line C and line D on the imbert chart. Of course you are stuck with the diams of your housings/firetube. I couldn’t meet all specs, but was pretty close and got real good results. So play with the numbers a bit if you like, but build your first one as close as possible to the “numbers” so you have an accurate base for comparison. My numbers are working great,imo, so I’m not changing them.
4a,4b,5,6,7 This is a perfect time to incorporate a temp probe. I have wanted to do this for a long time.
I’ll keep you posted,
Pepe
Here’s a link to GEK assembly.
http://wiki.gekgasifier.com/w/page/27905807/Assembly
Ignaz Roellin posted a pic of his heat exchanger on comment 298 here.
Hey Everyone,
Darned if it wasn’t almost 50*F sunny, clear and windy here today. I took some time and dismantled my gasifier for inspection.
Just so everybody knows what I am referring to. Left to right; filter, burner insert, hopper, burner shell on char base.
The deformation is evident.
Well, there’s a bright spot in this mess. Can you see it? How about melted steel. I’d say that’s an indication the temp there was approaching 2600* F, the melting point of mild steel. A wow moment for me.
Now for the fix, I hope. First I straightened the edge out with torch and hammer to receive the heat sink flange.
Welded top and bottom for strength and mass. No, it isn’t cracked.
Hourglass hearth with heatsink flange installed.
The hearth after 2015 operation. I recorded some of my hottest temps in my monitoring this summer , so I’m really pleased with the performance of my Fix.
Stay tuned for the rest of the story. Man, I liked listening to that guy. Oh, Paul Harvey btw.
Pepe
Pepe,
How much time do you think you have running the gasifier to get to this point? I’ve seen the video of you running a tiller before. Is there a particular engine you run with it?
Thanks for the pictures
Hi Bill,
Well, as a hobbiest and gasifier fan I have probably 60 or so hrs of run time on several engines. The small rototiller is 5 hp, the snow blower is 8 hp. I have a 13 hp generator that I will sacrifice, er, run this spring so I can see how the gasifier responds to loading. The small rototiller is the only one that I ran with a load so far and it responded pretty good despite under pulling. My imbert dimensions are line D, good for 45 HP. I’ve been toying with the idea of building a line A gasifier good for 15 HP which would be more in line with the HP range I’m working with. It would also be a much smaller unit. My brother offered me a good running 1964 4WD Scout for free. It has 92 HP and would require a line K imbert gasifier. Time, time, time. I’ve been busy keeping 4 rentals going in Tupper Lake. Time to sell!
Pepe
Or medium sized WK gasifier! :smiley:
