Real Deals , gasifier material and parts
Hello Kevin.
I think the 0-60 WC gauge would be OK
Thanks for the info WAYNE K and BOB MAC, Think i get couple spares or for my home generator project /asap, after my dakota truck refurbish/and gasifier.
I wounder if one of them 0-4 hg vacuum gauges work, maybe just no numbers too go by.
I think if you have two of the same gauge, you can compare them against each other. From what I understand your ratio will be the same ratio just in a different way to measure.
The dial on the 0-4 hg would react near the same as the 0-60 WC
I already ordered and got my gauges from Amazon for the next build, -0-30 wc from prm filtration on Amazon, now glad I did I just went to grab they link for them and they are currently unavailable
Thanks wayne K ,I thought it must be the same meter, since they have both readings on one meter/ being cheapy like this, i gess i could use a 0-4 hg meter/ and then put 4 or 5 marker lines on HG meters.I might do that if find deal on HG gauges.
Looks like all the hg gauges o-30 range, gess its back too finding deals on WC vacuum gauges, THANKS. LATER
