Yes Don same here I have two I ordered last year.
I use this brand in 4" - 6 blade for my single inlet pusher blower. Itâs a slightly different footprint than the Seachoice, so I canât use under the truck.
https://www.ebay.com/itm/SEAFLO-12v-4-In-Line-Marine-Bilge-Air-Blower-Fan-270-CFM/151999647743?epid=710536048&hash=item2363e28fff:g:RGcAAOSwKtVW1Nls&vxp=mtr
Carl, that blower has twice the cfmâs as the one I have. Do you throttle that 4 inch blower down to a 2 inch pvc? If so I wonder what that does to the air/gas flow? I have a smaller gasifier and engine so I think the smaller blower will work OK. I think I remember you saying once that your single blower works just about as well as the stacked blowers you first had.
Yes, I neck it down to 2" I was hoping the 6 blades would cram it through (power prop)⌠Since I donât have an exhaust pre-heater, it is a short run to the nozzles. Installed new last week.
Carl is that the only blower you have.
That is the pushing blower for making a flare. I have 4 suction blowers under the truck to induce a draft to get it started. These 4 can be run backwards to clear the oxygen from the wood hopper before closing the lid.
Ok thanks carl I will have to be working on that project soon I hope.
Good after noon WK Those prices on barrels look great, do you think they are the 28 pound barrels or the 40 or 48 Pound barrels, the blue ones i bought over here were 28 pounds though probley have too call too get the weight on them, if they are the 48 pound barrels i need a semi too get them out of there. My hopper heater welded on but it was thin welding with the 28 pound barrel. Maybe them are at leiste the 40 pound barrels.?
Good morning Kevin.
I donât know what thickness the drums are but looks like he has enough to build 2-3 gasifiers
Thanks Wayne two or three is better than none. And would work, be lighter, be less electric too weld. I could use two of them opened up too make one big heat sheild around my hopper heater as a exchanger.before insulating around the hopper heater sheild cover. those 28 pound barrels are easy too find.
Hey Billy North .
Hope you are back on your feet and feeling better .
I noticed 55 gallon drums reasonable down your way .
https://auburn.craigslist.org/grd/d/55-gal-drums/6533047527.html
Wow , lot of drums !
https://auburn.craigslist.org/grq/d/fire-burn-barrel-barrels/6766835438.html
Has any one seen any deals on gasifier vacuem gauges/ or are they getting low on supplys. I might be looking under the wrong search term name,?? THANKS
Good morning Kevin .
You may want to take a look at this .
THANKS WAYNE K , by time i git around too check that meter it was sold. there seems too be a shortage or WC vacuem gauges.
I found a o-60 WC vacuum gauge for 24.99 $ is that low enough or do i need 0-30 WC gauge.??
I would like that gauge for my truck, I pull over 30 in. on my cooling rails sometimes.
