Red bear, long grass mower on charcoal gas
Your work is excellent giorgio. So well thought out. Those lid hold downs are also kind of ingenious.
Giorgio, does it have enaugh power to mow nicely?
How many kw you got out of the generator?
Giorgio, excellent work. I can’t help but smiling - you seem to have a good supply of ss :grin:
Giorgio, whats the blue housing under the scythe lever for? I dont have that on myne
tom, the lids of the filters i can turn nearly in every position, this is a big advantage when connecting rubber hoses on different engines with the same gasifier…
kristijan, yes it mows fine and also has power…where i tried yesterday the grass is not so high because of much trees , it is a neighbours field or better woodland…in a week or so i will begin with hay on our fields…this year is a nice grass because of plenty of rain in the last month…
how much kw?
i would give the question to another expert of slovenia…you know.
he can calculate this things better, i am really stupid with electric stuff, must learn more…
i will fix the generator on a kind of slide with a motor and gasifier, in way i can bring it also to difficult places in the forest for electric chainsaw cutting…and for welding of course…
the blue housing under the lever for the scythe is where the racing cart is fixed to the mower
jan, i have only some flat ss sheet bought on market place for used stuff, except some pipes i must bend it mostly for different stuff like filter housings ecc…not always easy…would be nice to have a roller sometimes, but bending around round stuff like propan tanks or iron piping works also…i have a good assistent.
The Acme engine is 488 cc and has a nominal gasoline power of 12 ps at 3000 rpm, which is 8.8 kW. Giorgio improved the CR a bit by replacing the head gasket, so probably this old engine would reach these values without problems, well, running on charcoal gas it would definitely reach at least half the rated power, but I believe the power could also be 5kW. Such a generator from an asynchronous motor with a nominal power of 5kW can produce approx. 4 - 4.5 kW of power after three phases, but more than 2kW per phase (electric chainsaw 2.4 kW works at full power),… Older welding machine of the classic design, connected to such a generator, represents a rather large additional inductive load, so that it is not possible to weld on one phase (which requires at least 2-3 kW of power, but it is good to have 4 kW available), but if we use two phases, but it can be welded nicely, I tested this on a similar generator.
To summarize some information:
  • engine with a working volume of 500 cc achieves a power of 5 kW at 3000 rpm on wood gas (charcoal gas)
  • an asynchronous electric motor with a power of 5 kW - 3000 rpm needs a 3 x 50-60 uF capacitor for excitation and thus produces a power of 4 - 4.5 kW
…indeed the chainsaw runs strong…oak wood
the first bcs mower from 1945
found a voltmeter …can be useful for the generator
Test it for accuracy. There is usually a way to adjust it.
That’s a beautiful meter movement. It’s a bit higher than I prefer for generator voltage. Several times in my life, I became the shortest path to ground for 120 vac. I have not gotten used to it yet. I’m happy to live where 120 volts is the highest I’m likely to, umm, experience. Maybe the rare 240 volt appliance. I’m a big fan of 24 vdc, since I don’t conduct very well at that voltage :slightly_smiling_face:
the voltmeter goes up to 500 volt because of the welder, what needs 380 volt…all other tools have 220 volt here… my electricity mentor tone have explained to me, i can regulate the motor 20 volts higher as the tool requires, than , under load goes down…he has a lot of experience with such asynchronous motors for generator use…
a electric strike with this tension is deadly, i must be careful…otherwise one chargasser less in the world, there are not so much…
yesterday on the red bear mower during work the clutch not separated more motor and gears…
interessant clutch construction with a lot of discs- friction surface…after cleaning , rust and dust and giving some oil on the clutch fork bearings, it works well again…
our driveway is actually full with high grass and must be cutted, 2 km long -test
mowing on chargas is every year fine again…
I was always told it’s not the volts that kill you but the amps.
It’s the volt’s that pushes the amp’s through your body :slightly_smiling_face:
the mower got new cutting knives, in tractor quality, 3 mm thick instead of 2mm…
but the weather isnt good yet for cutting more grass, so we tried a welder, what has had a burnt primary winding, recently repaired…and it works again.
we have found in the "collection " on a trafo the same kind of wire, 1,3 mm thick…
should the "new " windings be threatened with paint for glueing together??
the honda generator gx 200 on chargas with 1,5mm elektrodes…(switched on 1)
thicker elektrodes i think the generator is not able to handle
You are amazing Giorgio, rewinding transformers is no childs-play :+1:
I would ā€œslab onā€ some good epoxi varnish, it helps keep the windings steady.
The windings actually move some when using transformers like this, magnetic force, when moving they tend to rub of the enamel on the wires, wich leads to short circuit.
The best way for varnishing coils like this is to put them in a vacuum chamber, to get as much air out as possible between wires, and soak them in varnish under vacuum.
But not necessary for your welding transformer, as it’s pretty thick wires, and not so high voltage.
I didn’t think paint will work that well
Usually the wire is coated with a polymer plastic, but they used shellac for decades.
For gluing the wires to together, usually they use i think wax, but the process is called ā€œpottingā€, because you stick it in a pot and let it soak in between the wires.
Potting isn’t strictly necessary for operation. It just helps prevents the vibration which work hardens the wire and makes it brittle, then it gets microfractures and which increases Resistance so it gets hotter then the varnish melts and the coil shorts. So basically it lasts longer. :slight_smile:
And on that note, you might have been able to reuse the old wire, anneal it by heating it and recoating it.
