Saman's gasifier project
From my understanding, colors are not important. What is important is to have engine grade fuel. I do believe you have that. In my opinion, you already have a better gasifier than the one that is in the video you posted. I am very impressed of how you’re already advanced. Keep up with what you are doing and pay no attention to what you find on Youtube. You have the best people in the world advising you. Take their suggestions to heart and apply the knowledge you desire.
If I was in your shoes, I would be hooking your unit to an engine. Once that engine is running on wood gas, you won’t be able to contain your excitement.
Hi Mr Bill Schiller
You gave me so much energy with this text.I believe in each individual in this group.
all of you are the best
I will definitely do this.(hooking my unit to an engine).but i have to do some thermodynamic and chemical test until my thesis defens.
after that i will do everything.
Thank you so much
What Bill sayd.
Yes, perfectly blue flame is possible, but beweare! Pure blue color does NOT mean perfect gas in terms of caloric value/flame speed. The real energetic gases like hydrogen and methane colour the flame kind of orange, but different from “tarry orange”.
Max, l am not sure if Saman followed my skizz exactly, but he did post the skiz with measurements a few posts back.
Hello Saman,
The Below video shows motor grade gas burning at night.
It is hard to see in bright day light but at night it shows well.
Hi mr wayne
This is really big gasifier festival :blush:
But in your video you have a blue flair in 1:22 time.
Is that diffrent system?
Saman; I repeat myself, as I understand this is for a “paper” for an advanced degree and a “proof of actual use” demonstration. For the true purpose of this project you should do as I suggested in post 111. At the risk of being accused of putting words in Max’s post, he is willing to help with the same calculations. ALL calculations start with the size of the engine and RPM it will be turning. Decide on that and give Max that information and as he has done for others, will look at your skizz and check for modifications based on known calculations. TomC
Yes it is a different gasifier design than most at the event. It is a MEN ( Mother Earth News ) design .
It is mounted on a farm tractor and was just getting started. It may have changed colors after warming some .
I use torches so much that I do not pay attention of the color but I bet if you light a cutting torch and watch the flame it just might change color as you increase the O2. Starved for O2 and sooth might form and glow changing the color but yet the same gas. Different air to fuel ratio, different flow rates etc.
Hello Saman
Maybe you could tell us the statement from your Thesis?
What finding/truth are you putting in writing, needing defending?
This is the challenge you have with papers for degrees people.
You have said needing to make producer gas for compressing. For storage? For later heating fuel substitute uses like flame heaters?
The needs for these are very much different than internal combustion engine fuels.
Heating fuels for cooking especial must not transfer unsavory flavors over into the food, or the cooks working area. Why “clean”, “clean” fuels are favored for foods cooking. Even liquid gasoline fuels stove use a very special grade of purified gasoline. Put regular engine gasoline in a cooking stove and stink! stink! stink!
Space heating fuels not so critical for not-pure-blue flame. The not under pressure combustion products are carefully duct-ed outside away from people.
Motor grade fuels as an example are stinky, staining, actually hazardous for breathing and skin contact. They NEED the higher energy density as well as satisfying the engines needs to controllable speed/flame-front combust under pressure.
The ONLY way to judge internal combustion motor grade fuels in-use by combustion color is viewing it while under pressure/temperature loaded conditions in a working engine. This is done with special engines with view-ports. And this is done with special quartz glass center spark plugs.
The historical papers and readings Tom Collins and I have referred to will say there was even a different need for light illuminating producer gases. Heat unwanted byproduct to illumination. So not the high energy density needs. Needed to have available free carbons to burn and yellow glow for the illumination.
Yes too many words by me.
Summery.
Different fuel, or HC input stocks gases are need for different downstream uses.
No ONE gas can satisfy all needs.
Blue flares are cooking gas flares.
You approach by making the best gas for a single purpose need. Using the raw input stocks best to satisfy that ONE need optimally. With sub-optimal results for other use/needs.
Or . . . . you have a free-waste input stock and make the best you can make with that. THEN narrow down the use/needs to what you can make from this free-waste input stock produced gasses mix.
I hope this makes sense to you.
This is how the real world works to get things done.
You would not want to walk in my boots. Heavy rubber with thick wool liners. For COLD, freezing wet mud’s.
Your feet would overh heat and sweat.
Wearing your boots my feet would always be wet and cold.
Producer gasses (and thier open combustion flames) come in many best0use variations.
Tree-farmer steve unruh
Hello mr Tom Collins
I will definitely use your advice.about (GENERATOR GAS The Swedish Experience -Gas 1939-1945)
i have started to read from yesterday.
in page4 line 20 you can see this sentence: (The limousine shown on the cover was initially intended for the Shah of Iran, but when the Shah died, Harry purchased it to demonstrate gasification at Eastern Universities and lecture on alternate energy).Maybe I can borrow it on behalf of Iran :wink:
Yes it can be possible.but the use of pure oxygen is not economic
Hello Mr SteveUnruh
good time.
Thank you for your guidance.
My goal in the thesis is to show the values of thermal value and system efficiency.With different fuels including compost mushrooms
My goal is to compress gas was to carry it to the laboratory.But I found special bag for carry the gas to lab and I do not need to compressor for now.
Thank you so much :blossom::blossom::blossom::blossom::blossom:
Who is Harry?
One of the founders of the gasifier industry.(1939)
Saman, thanks for the information
excuse my lack of culture
I think maybe “Harry” was Mr Le Fontaine? Actually a Danish-American naturalized citizen who adopted his wife’s name.
He initially learned gasification in occupied Denmark WWII as a slave laborer.
Later life in America post-1974 he made up a trailer mounted woodgas system for his hot-rod modified large engine V-8 Lincoln sedan and toured around to US Universities promoting Producer Gas as a viable alternative motor fuel.
Major author contributor to the “Producer Gas: Another Fuel for Motor Transportation” publication. ISBN 1-4102-1605-5
Article in the library on Harry La Fontaine: Library / LaFontaine Article | Drive On Wood!
Hi, Kristijan!
11.11.2017
Ref. mess 136
Yes, he did put the cone outline measures following your instructions, but there it seems to have ended!
You did instruct in the beginning to use at least two opposite nozzles, and later in the photos he had used 5.
Later, it seems, that he has payed no attention to the coarse rule I gave for a hearth of that estimated size.
If a highschool student does not calculate the area of a circle = a nozzle hole and multiply it with the count of nozzle-tips, how can he then calculate the ratio between the restriction area and the sum of nozzles area???
Throwing bits together like “over the shoulder” paying seemingly no attention to measures given, keeps me “out of those waters”.
Not even later providing any kind of measures, makes correcting instructions invalid.
The soot content of lightly filtered gas is mostly orange-reddish. Tar content tints it toward yellow…
Still, undiluted gas usually starts off a pipe-end with a little bit of blue. In this case shown, the outlet was ejected with pressurized air and diluted…
I first advised him to change the existing gasifier to get best possible gas out of it, but allso advised, if possible, study and build a new gasifier. He asked me if l culd draw a plan for a simple basic downdraft gasifier on pm and l did. He allso folowed the advice given by TomC (and others includeing me) on reading trugh the generous library on this site.
As Saman sayd above, he did made a entirely new gasifier based on the basic lmbert plan l gave him, 5 nozzle 5 cm restriction, for experimenting and defending his theais, after wich he plans to make a “real” gasifier to power a bigger plant, and l think he and we all know that will be impossible without extensive research and reading tons of books and experimenting.
I see no problems in guideing people with drawn plans and similar advices, as long as they show interest. If there wuldnt be generous people from this wery site that helped and guided me l wuld still be lost in the dark, trying to power a 50ccm engine with a restrictionless 5" gasifier.
Hi, Kristijan!
11.11.2017
I am glad that you have had some response to your effort! I hope it ends up with success!
