Wayne's International 444 farm tractor project
Hello Kristijan
You can go here and find all the details. Drawings, pictures and videos .
http://forum.driveonwood.com/t/waynes-international-gasifier-build-thread/1209
There is a canister on the left side of the tractor that serves as the condensate tank. It is post cooler rails and severs same as the tank I use under the trucks at the rear of the bed. .
The gas travels from the condensate can over to the right hand side of the tractor where the canister is filled with hay .
No more rinsing of the hay than the bigger filters on the trucks . The tractor uses much less gas than the V-10 or V-8 .
Thank you! I read trugh that topic too but looks like l missed it. Thanks again.
On the tractors I built I brought the woodgas/air mixture in above the carb( updraft carb) . It can be done, just takes a bit till sort out.
