Good morning Kevin .
I believe it is about 4 months the grass doesn’t grow.
That sounds much better than about 7 months in this side or end of the country.Our grass mostly stops growing most of october till half way into may or first of june. It might not get too long before some time in june-depending 0n the year. HAPPY SPRING TIME.
Nothing new or exciting just daily DOW stuff ![]()
( sorry about the shaky camera , should have used my cap-cam )
That was fun ride, and it wasn’t to cold in the back of the old wood burn truck, the heat coming off of the gasifier was almost like sitting next to a wood stove or a burning barrel outside. Nice. Hi Lisa, you sould do more of the camera holding, you do a great job with the camera taking videos. We then would be able to see the SWEM on Wayne’s face more often. HWWT.
Tone, you are not in a short supply of rock, gravel, sand, and hard work with that crusher. Making it all on wood gas for the most part.
I tried to do like you this morning, it went very quickly to ready gas, only a few minutes at a slightly higher idle, before I could turn off the gas, thanks Wayne.
What do you think the tongue weight on that load and trailer is Wayne? That’s a far piece from the front axle to the hitch. A far piece. I thought I’d through in a little good old boy talk to show I’m not an uppity yankee.
Hello Tom
That is an old heavy trailer I built back in the late 70s and just a WAG I think it would weigh 6-8 K and I think the load would weigh 5-6 K . So another WAG I would think the GN hitch weight would be just less than two tons.
The shut down of your truck is as simple as you can get.
NIce work sharing your wood gas powered vehicles, AND the design that has over 250.000 miles of prof that the design works well with dry wood as it should- FROM the book HAVE-WOOD-WILL-TRAVEL.AND THANKS FOR SHARING YOUR DESIGN- WORKS GREAT.
Looks like your grass is perking up- we been getting a bit of rain too- though it looks dry for next three weeks after this week-for april showers- not that many rain days. OR i should say hay- IS hay just tall grass or a certain type of grass?
Hello all .
I turned the camera on for just a minute on my driveway on the way home .
I have dumped my hopper juice several hundred times while driving in but the streak from yesterday afternoon is the only one that is kinda visible ![]()
HI wayne i dont remember in the cab hopper juice draining in the book- Though that could be handy on a curve,if weardo was chaseing.–JOKING.I got too hook up an in cab hopper water and maybe a cooling rail in cab water drain cable lever. IS there a revised -HAVE WOOD WILL TRAVEL- book or not many revisions.? THANKS. P.S. i wounder if any of them motorized ball valves work with water draining with out valve sticking from the tars in the water zone.
Hey Kevin .
I will take some pictures and be back with you ![]()
