What does it look like above and below the grate, can you make a sketch?
I hope this may clarify some?
Condensing hopper.
Grate upgrade.
As the arrows show, the gas must pass the holes in the new grate, not taking the shortest route out.
Thanks Göran, I didn’t understand how you were going to do it with the grate, you’re a bit of an artist.
I think that is the artwork that is going to be painted on the outside of the gasifier or on the truck itself. In the US, we use bumper stickers, in sweden they have their own custom drawings. ![]()
Yes, a gasifier pipe, tar and carbon monoxide straight down the lungs ![]()
Exactly Tone
plus i added the scraper, as is popular in Finland, as they often run their gasifiers on briquetted peat, peat ash has a low melting point, and a aggressive grate cleaner like this is necessary then.
For me it’s just a double solution, maybe helpful when using smaller pieces wood, and driving on bad roads, which will make the reduction charcoal very compact.
Well, whats happening? Is there any progress? Yes, started working on the gasifier this morning, and really raced..
Some pic’s:
Wheel hub turned down.
So an old flexplate fits, i plan to power the grate scraper with an old windshield wiper motor.
22mm deep socket, i welded on some material, and turned it in the lathe so it fit snugly in the hub.
Socket welded in, and gasket cut.
Test-fitting in the gasifier.
Test-fitting
Next step, some insulation, and a piece from a gas bottle, to act as a heat shield for the bearing.
Hub got bolts for the flexplate, the bolt in the center is where the connection for the bottom nozzle will go. This will be a combo of a “Mikkonen scraper” and a “Tone nozzle”.
The scraper shaft, three 4mm holes drilled, and top welded tight.
Nozzle and scraper.
New restriction/ choke-plate in place, sealed with chamotte-clay, with some iron shavings mixed in.
Hopper in place, and everything tightened. Dark outside, and raining.
Round up the days work with a night swim, to get rid off soot, itchy insulation, asbestos dust, red silicone, tar and so on. Cold.
Firing up gettin’ closer. Tired now…
You did all that in one day? Well thanks very much for making me feel like a complete slug.
What Tom said, productive day Goran. You only missed the leak test like you did on your tractor.
He probably doesn’t want the truck in that water for a while. After swimming in it he’d better wait a few days until the pikes cleaned up the lake from asbestos, slicone and tar ![]()
Goran, good job, well, the maximum engine vacuum acts on the openings of the grate and decreases upwards between the filled charcoal, so the air inlet must be about 10 cm away so that the oxygen is consumed in the charcoal, this way the charcoal is converted into gas and ash, and space is created for new fine fuel, this way the scraper will rarely work, you will even want to cover the openings in the middle of the grate with a sheet metal (as I drew in the sketch),…
Hi Tone, thanks for the response.
Well, this is a test for trying, the pictures is “lying” some in this case, the holes in central nozzle are actually 90mm over the grate, in pic’s it looks like its flush with scraper.
The middle cover is something i could “incorporate” with the scraper i think?
Edit:Well, the pic’s aren’t lying
It’s just that, i had the bearing propped up on a jack… it’s higher now when the bolts is put in and tightened… sometimes brain, eyes, memory, and everything don’t work as supposed
I think i need to lower a camere in the gasifier to convince myself i did it right.. and dont messed up..
Goran, I do not doubt your expertise and experience, take my writing only as a monologue of thinking aloud.
If we look at the gasifier from the outside, we can see the relationship between the air openings that supply the upper nozzles and the hole with a diameter of only 7 mm, which allows air to enter the lower part, after all, such a small cross-section cannot cause even a large “hot leak”. I find that it has a very favorable effect on loosening the lower part, which allows easier gas flow, and this also means that the remaining oxygen from the upper nozzles more easily reaches the lower areas, even below the limiting opening. The philosophy of the size of the limiting opening also changes considerably, because now the conversion of tar gases can take place all the way to the grate, since air jets on all sides provide the conditions for conversion. To conclude my thoughts, the limiting opening should be 20 - 25 cm in diameter, which will allow unhindered filling of the lower part, and the resistance of this gasifier will be very small with large gas production.
Hi Tone, i got the deepest respect for your knowledge in gasifiers, and i can see the benefits of the lower nozzle (even if im still little nervous about the “hot leak effect”
Well, i prepared for this nozzle, and it’s pretty easy adjustable from the bottom. Im going to put a insulated tube from air chamber to the nozzle in future (to get clean, and somewhat preheated air in).
It is interesting to investigate the possibility to use a bigger restriction with help from the nozzle.
Im going to put in here some drawings about the “balance” in charbed, and some thougts about it.
For now i focus on get the Chevrolet running on wood again, i really miss driving on wood..
Some pic’s again…
A view down the hopper, the clay seal should have dried enough now.
Some homemade charcoal for the “pre-fill”.
Some nice birch on top of it.
I build a new glow-plug for the pyro-starter, the old had corroded badly. I found a 24 volt one, had to shorten the nichrome wire by half for running 12 volt, pretty finicky to weld this thin wire to the connector. But it worked!
Professor Baltazar strikes again. Not long until lighting.
Well, it’s done! I need some work on the scraper and bottom nozzle, and i need to find a windshield wiper motor (thought i had a dozen laying around, but can’t find any 12volt) for the scraper.
But it’s working ![]()
The pump for the igniter had corroded badly of standing in a mix of gasoline and diesel, stuck.
But cleaning, lubricating and a new, homemade strainer made it work.
Time for test:
Light-up, a silent “pooof” tells the pyroignitor works, a tiny bit of smoke coming out the chimney.
No smoke without fire.
Venting the hopper some times, to let of steam, and spread the hot-zone upwards.
Which is visible on the decreasing amount of smoke coming out the chimney.
Finally, a stable flare, totally impossible to catch on camera.
This new-fill-up start-up took around 20 minutes, which is the fastest first-start with this big boy ever.
No starting of the engine this time, now it will stand and “settle” some, and to burn-in the clay seal.
But tomorrow maybe a trip on wood? Can’t wait, im happy as a pig in sh*t, is this the woodgas bug, still after all this years?
Need to send wife to buy lemons for tomorrow, or maybe i could use brake-fluid? It tastes bitter enough…
Goran, I’m already looking forward to riding with you, well, you said there was some smoke, … this is what a quick start-up (about 3-5 minutes) looks like after about two hours of work - sawing and loading firewood, pushing the moist flue gases through the chimney, and a slight mist on the front of the refrigerator, … there are not a single mosquito or other insect for 100 m around, …![]()
