Well since we are comparing . . . here is our latest Grid electrical billing:
A wealth of information here.
Very cheap by the kWh at only $0.0766. Now the $26.73 monthly base by 12 at $320.26 annual buy-in to have access to that low kWh is significant!
But consumption costs do add up with minimum of two; and at times four; females in the house.
Yep. Yep. ALL the lighting except for two ambience Lava lamps are LED.
ALL appliances are 21st century low energy except for one retained big old chest freezer holding six months worth of meats. Figure it is $8-15 a month of that costs.
We are very well insulated in the ceilings and floors. Walls adequate. Vinyl framed double pane insulated windows throughout.
As this bar illustrated history of two years shows we do need heat for a full six months of the year. And now with this house, for the first time ever in our marriage, we do use some electric heat pump air conditioning in the three hottest months.
Using wood for heating saves at least an average of $100 a month for six months.
The straight electric hot water heater and the freezer, along with two older high efficiency refrigerators live in an unheated larger lower level multi-purpose room. So converting to a newer lower electrical use heat-pump hot water heater would be sucking heat out of the room needing some kind of heating for 9 months. Add future repair complexity.
So yeah. Lots of different way I could skin our home electrical use power supply costs.
BUT; the big Butt . . . any complex system I would set up would not be maintainable; or even operable by any one of the four females in this house.
Just in this last 9 months in clogged drain plumping fixes (long girl hairs and soap scums); leaking worn faucet seals; and the clothes dryer needing work twice I have saved the household a minimum $500. + $300 + $200X2 in 30-40 miles call-out service calls.
I am 73. The need for simple systems, affordable, for soon down the road service calls; $'s out weighs all monthly Grid buy-out considerations.
Now the Grid Down then a whole deck reshuffled consideration all together. Quickly those long hot girls/women daily showers; and daily and three, some times four, big full cloths washing (with hot water) and six months full electric cloths drying usages gets re-set back to boy/man standards. One-load washday, one day of the week.
Outer wear worn for 2-3 days. NOT up to three clothes changes in a single day.
Pretty simple to me now. Do not complete/compare to Big Grids in costs and capacity.
And this is addition to Washington states nearly 50% taxed higher pump gasoline and diesel costs versus the majority of the rest of the continental USofA.
Our now Washington in-state 100+ data centers: Yes! A costs upwards driver for all here.
Our state mandates insistence to fully vehicle electrify is much more the costs for all upwards driver.
Every singe full EV operated here uses the Grid electricity of one average household.
The angers of this is now ground swell raising from the common folks. The political heat from these disparities is no longer a simmering bubbling out here. A constant roiling, low boiling. Building up to a flashing into steam.
The last thing I want is to paint myself as “one of Them” with hundreds of feet of PV obvious.
Instead I will remain painted as a 19th century archaic stuck in the past with wood heating.
That does happen here much too. Through our home owners insurance companies.
