Chris, I know this is an old thread and not sure if you’re still doing research or not - but I thought I’d chime in. I have an old TD9-91 with the IHC D350. It starts on gas, then switches to diesel. You can control the compression ratio with a lever 6:1 to 17:1. No glow plugs, you start on gas to warm it up, then flip over to diesel. 350 CI 4cyl, between 60-70 hp. has carb, mag, plugs one side and injection pump and injectors on the other, really throws people for a loop! These engines also came in old IHC tractors, power units, etc… It would be a cinch to run these on gasoline at 6:1 and then flip to wood gas at 17:1 CR.
Chris,
How bout a 1991 M998 Humvve with a 6.2 liter diesel engine? Would that work to add a wood gas system? Would the wood gas be powerful enough to move the thing? It is a heavy truck.
Allis chalmers made something like that might be one is made for the other company for all I know. But I saw the AC version in person when I lived in Ohio for a summer years ago. Those are massive I could plow my entire field in a single pass with that rig I think of course then it would be stuck at the far end with no way to turn around and leave. Lol but they are nice rigs and will pull the world.
Steiger made them for IHC and AC if not more. This one started out as an AC 440 but when farmers traded them in the the Steiger dealers sometimes painted them Steiger green. The 440 was basically a Bearcat but I think they look like the Wildcat. I’m amazed how well they maneuver/turn.
About the easiest tractor to work on. They liked to use truck parts. The Steiger brothers started making tractors in their barn. The first ones they called Barnies.
Wow, that’s a beast!
What does it weigh? How much HP?
if it is actually an AC 440, then it is 20,230 lbs, and 218Hp with a 9.1L 8cyl cummins diesel, and a 10speed F 2R tranny.
http://www.tractordata.com/farm-tractors/000/1/8/188-allis-chalmers-440.html
Those are my kind of numbers!
My TD9-91 DROTT weighs about the same, but down about 160 hp compared to that beast.
I’m actually surprised it’s not heavier, probably that’s a bare stripped down tractor weight. The TD9 weighs 10,000 bare, put a loader on it with all the requirements thereof - 20,000 lbs😄.
Yes tractor data has the bare tractor weights it mostly cones from dealer data sheets used to ship the oem tractors.
Hello Jesse and welcome to the site .
There have been a lot conversation on diesel conversion to woodgas .
You can go up in the top right hand corner of the page and search DIESEL.
Here is one thread .
What Sean said. The manual says that the 3pt hitch will lift 9500 lbs. I’m a lucky boy to have that old girl…!!
When I’m trucking down the road neighbors flag me down and want to see. I enjoy talking with them about that old iron.
I wouldn’t pass up a Steiger skidder.
I also wouldn’t pass up a Big Bud, they are at about a 1000 HP I’m told.
i’m jealous. I wish it would have followed me home. But alas, I wouldn’t have a use for it, or a place to keep it, but always thought they were sweet.
And just for the brainteaser, I would have to think about converting to a hydraulic drive run off an electric motor and a huge lion battery pack namely because I am too cheap to want to pay to fill up the tank just to mow the lawn. lol
My mouth is watering lol! You should have a look at skadill YouTube channel. He goes out in the woods and finds old abandoned logging equipment. IHC 175’s, D4/6’s even old steam shovels, plus some crazy stuff I’ve never even heard of before. I’ve got 31,500 lbs of old yellow stuff out back already, my wife would hang me from a tree if I dragged something like that home!
LOL nice vid. I will remember to put waterproofing in as a design constraint. I will probably have to build my first one by swanking parts from the local nuclear sub dry-dock instead of the local quarry like Stieger’s did.
I have Belarus 826 Turbo -89 and Deutz D40 S -64 with never 52 Hp engine from Deutz Fahr 600.
Wayne, did you use woodgas in the Fordson?
Hello Philip.
I did not gasifie the old fordson major .
I did gasifie a gasoline tractor .
