Drawings of charcoal gasifiers for vehicles
Thank’s a lot Chris. I wanted to update the site where it can be download on PDF for FREE, my last version, in English, of my Guide: Drive on waste. at the post 12 of this topic.
Here again: My last version on PDF, in English, of my Guide: Drive on waste. can be download for FREE form my website: www.autoabasura.com
B.R.
Eddy Ramos
Hi Tone:
Thank’s for this new drawing. How it works? For how long you have being using it?
What your experience is on it?
B.R.
Eddy Ramos.
Hello Eddy, after a long time you are with us again, we missed your company and your drawings, … I tested this idea on my gasifier on the tractor and first installed the middle nozzle first just above the restriction opening, and then, due to the increased resistance in the lower part, dropped below the limit in the “forbidden area”, initially a few inches lower, but now even lower and with a larger diameter of 6mm. I wanted to achieve gasification of fine charcoal mixed with ash and thus cleaning this part of the gasifier. The sketch shows the changes, namely the inclined vertical grid, so that the openings between the elements are narrower at the top and wider at the bottom. It is also possible to weld additional sheet metal to increase the surface area, which would further improve heat exchange. Well, in this thread there is some philosophizing about it and some pictures, …
