I got an early approval for a 5MW Biomass plant with a major utility. I need fuel..You can help
I got an early approval to sell biomass power to the grid with a major utility . I get the same business arrangement as a solar field. I am biased toward biomass but after reviewing economic engineering information I learned there are sixty solar plants to each biomass plant. I see writing on the wall.
For now I need lots of green methanol. If you can make industry quaily methanol you can enter into a ten year fixed price cooperative agreement
The scale is approximately one half semi trailer of wood everyday. One ton wood is 2MW methanol 275 gallon totes OK High quality tested incoming loads Midwest location.
There are two types of Methanol:
1)Etsy Methanol - wet destillation and dry distillation
Dry looks fastest and best
Wet distillation There is anylase reactive pectin in sugar beet pulp and protien hydrogen too.
It helps to keep bark out of feedstock as bark is heavy with medicines rather than fuels.
There are no tars; there are compounds that have tarry like characteristics and are likely tree medicines at the bottom of the column
The top of the column at 212Fs turpentine, fomate, acetate and …These are fuels or worth cash
Methanol alone comes from the middle of the column.
There are different temps for wet and dry and for slurry. The resudue is non toxic snd degrades.
2)Catalytic Methanol - uses a semi trailer portable caralytic plant that needs merhane that doesnt exist and must be made.
Needs methane needs sabatier catalytic reactor for matching input methane volume uses syngas and extra hydogen
These units are modular and are meant for use with large volumes of well head gas and work with green methane but with fewer hours at the same production rate because of the difficulty of obtaining large amounts of biomass feedstock . This machine can process fifteen semi trailers of twenty two tons of wood each day for 660 MW worth of methanol . This is a small machine in the oil and gas industry.
This machine makes for a much wider based feedstock available available for something other than direct combustion.
I would look at producing wood vinegar… You do get some burnables off it that could potentially run a generator. Then you have the actual distillates which includes a bunch of stuff along with water… and then you have the charcoal/biochar ash, left in the bottom. When I looked at it a few years ago, if you dewatered it, you can sell it to a refinery. When you dewater it, you want to do fractional distillation because the methanol will come off at say 70c, and you can recover that portion, and ethanol at like 80c, then you get to 100 and that is mainly water, and I think you are supposed to go to like 103C to make sure you got all the water. Then it is good to go.
You go through more raw material which is more work though, and the 5mw power is greatly reduced. And when I looked at it, anything over like 50kwh output they had a bunch of regulations as far as when you could generate, and you had to notify them when you went online, etc.
I’m no economist, but with today’s rising prices, entering an agreement this long as the supplier raises concerns.
Thank you for your reply. I liked your reply because it confirmed what I wanted to hear. Yes - wood vinegar. I have the idea Id get results Yea I heard the high temps are above slightly above boiling. That confused me. Id like to do everything on site.
The bark and leaves makes tar. Tar burns but slowly like spa heat.
Acetate is microbe food. I try to use sugar beet pulp. That might work together.
I decided to use a heat gun gas heater instead of a gasifier. This heat gun comes with 20 cuft per minute. Thats good torque. 0 - 1000 F
I attached a 20cuft per minute Nitrogen generator to push the heated pressurized O2 free gas around. That helps circulation.
