Wood Gas Generators for Small Power Requirements From the article: Experimental and developmental studies were conducted for about 12 months on wood gas generators meant for running 5 hp diesel engines used in irrigation water pumping. Based on the critical design inputs obtained during the study, a prototype of the gas generator has been built and tested along with a diesel engine-pump set. The results of various tests on the system indicate that the' lowest amount of diesel required to run the engine on wood gas is about 15% of the normal consumption. On the other hand, for obtaining the same work output, that it is for pumping the same amount of water at a given head, the best replacement of diesel obtained is about 75%. The paper also includes some comments on the cost of such systems. About Us Pellentesque habitant morbi tristique senectus et netus et malesuada fames ac turpis egestas. Vestibulum tortor quam, feugiat vitae, ultricies eget, tempor sit amet, ante. Pellentesque habitant morbi tristique senectus. Address Twitter, Inc. 795 Folsom Ave, Suite 600 San Francisco, CA 94107 P: (123) 456-7890
This is a companion discussion topic for the original entry at http://dev.driveonwood.com/library/small-woodgas-generators/
