Škoda pickup on wood
Played and experimented with the gasifier a litle bit. Decided to put it on camera. Its a long video, feel free to skip. At around 7 min l managed to light it.
https://youtu.be/-1RL0Qjuupw
So, l wanted to try what happens if you only use wet charcoal in the sistem. And l do mean WET. Like literaly soaked.
As expected, its hard to light and my first atempt to light it with engine suction failed. Had to bring the shopvac in. After the charcoal lit it started producing gas quite fast, and, ofcorse, a lot of steam. I was amazed it lit at all. And boy what a flare! This was the first time l tested it at dusk, on previous test l flared at mid day and l culdnt see the flame inside.
I regret not filming it but to much of my surprice the engine cranked right up on gas. And l did not excpect it to run nearly as well as it did.
Now, before anyone starts crying for that engine abuse let me calm you, this trusty old Seats life has expired and its in its last month. Only registred till October, then it will be scrapped so it can afford a bit of fun before death :smile:
Even thugh the gas is super wet and not the richest from all the steam cooling the gasifiers hearth, engine reached redline wich l dont recall ever acheaving with a updraft gasifier that was mounted on this car. Throtle response was similar to that of petrol and it even idled well for some time, untill the steam cooled the gasifier too much…
This test was primarly made to test the gasifier and cooler/filter temperature on real engine draw even with wet gas (steam carrys more heat), l dont want overheating on this thing. And it was an absolute sucsess, even after this overdraw torture the whole sistem can be touched.
I also noticed a big improvement on sistem drag compared to my previous sistem. This air control flap is from my Mercedes and l seem to recall there the the valve was set to about 25% open for the engine to run optimal, here it was 50% wich suggests both the gasifier and the towel filter are nicely flowing, even being soaking wet.
I also brought the Škoda home yesterday. Have a licence plate light to fix then its time to mount this thing on…
