So at argos 2023, a young man brought up the concept of using thermoelectric pads to generate power with the heat from the gasifiers. the general consensus was agreed that the pads (at this time in technology) dont generate a significant amount of power by themselves to be something to rely on…but its been scraping at the inside of my head since then.
i started thinking to myself, yea a pad or 2 wont charge any batteries in any significant measure…but what if we change the goal? reduce the power?
After some very basic research, it looks like you can get units that can generate up to 125w, but depending on size you can look at individual pads that can generate between 1-125w, and can THEORETICALLY be setup in a modular connection to get up to 5kw (this amount doesnt seem cost/effort effective from what it looks like is required, but i wouldnt be doing my due diligence if i didnt at least mention it) and they dont seem to be very expensive ranging around 10-30 dollars USD for the average sized ones. but for most setups ive seen online your looking at 125w and under realistically. though im sure someone smarter than me will have already made a much more powerful proof of concept, lol
next concern is temp range. they seem to have a “hot” and “cold” side and they dotn seem to really care about weather its hot or cold, it just cares that there is a temp difference. So the “hot” sides seem to be able to handle around 600 degrees Celsius (1112 F), and a 30mmx30mm (1.2x1.2 inch roughly) unit could put out on average 5-6.5w. adding some sort of heat sink would be ideal i imagine, but heat sinks are ALREADY part of an efficient gasifier system so it just happens to be in the right direction.
the temp can EASILLY be worked around, by adding a separated shield, or just measuring the temp range on the unit and figuring our where the best placement is, 1,112F is VERY forgiving.
now a car ac blower is definitely not something that would be effective as they generally use 750ish watt per HP. BUT there are a TON of power efficient blower style and squirrel cage style fans that use as little as 12w (granted, these ARE relatively small and are most commonly plastic, but there re metal ones too), BUT this opens up an interesting thought experiment of using the initial warming up heat to power a small fan to pull air through the system, thus cutting down on startup time and removes the need to plug in your fan to an external power source such as a car battery while you wait for the system to warm up enough to get the motor/engine up and running, then let it do the work.
granted this would probably take a little longer to get started up without an external power supply, and the thermal pads themselves wont generate enough power BY THEMSELVES to do anything major, but powering a decent sized power efficient fan is VERY doable. The concept may lead to a self starting system that would benefit initial starts. conceptually the idea has been beating me in the back of the skull for half a year, so i figured id toss it out there.
