Thinking about an adjustable tri-ball hitch for a woodgas trailer build?
I’m working through the trailer side of a woodgas setup on our small place outside Jackson. The gasifier and blower are going on a utility trailer that I also use for firewood and general hauling, so the drawbar height changes depending on which truck takes it. A fixed ball mount has been a hassle because one truck sits higher than the other.
I’ve been looking at adjustable tri-ball hitches since they cover the common ball sizes and let you set the drop, but I’m unsure how much slop the adjustable joints add over time, especially on washboard gravel roads. I also don’t know if the extra weight of the adjustable head is worth it for a trailer that’s mostly empty on the return trip.
Has anyone here run an adjustable tri-ball mount for a woodgas trailer or general farm hauling? Curious whether you’d go that route again or just keep separate fixed mounts per truck.
