Hi MarcusN.
David Siedschlag is the member here who DID woodgas his Toyota pickup 22re.
Read here:
This was in 2013.
He later offered it up for-sale here in 2018:
And in between he did make comments about his systems performance on others topics threads.
You goals sounds realistic.
On your engine re-fresh see what you can do to bump up the compression. Even if you’d later have to go with premium unleaded gasoline.
Sound like your are using at 4000-5000 feet? Power deration just for that.
I do not know about the camshaft.
5-speed with it’s overdrive, YES.
USE PROOF is what matters the most. Do not get trapped into “hydrogen-fast”, “CO fuel gas-slow” talking/over-thinking traps. Use it to find out. Different engines in different applications giving different results.
