Göran, I did see the fire extinguisher, but what caught my eye was all those treassures to the sides. The “dymmel”-auger for example. I used one for a cleanout auger for my first gasifier.
Next post popped up. That’s a really shallow heart. Are those Imbert dimentions?
Hi Cody, that is just the answer i wanted, i was on the right track, i have tig- nozzles 8, 10 and 16mm and a piston wrist-pin 15mm inside, i’ll see what i use. For the rpm, i have no idea, going to try to measure it this weekend.
I made my guess with 2000 RPM. It probably idles at 800 or 1000
With 8 or 10 you won’t have excessive air velocity so I wouldn’t worry about blast effect.
Yes, i have lot’s of good-to-have stuff laying around
As for the dimensioning i used SMP,s dimensioning tables, should be close to Imbert dimensions.
Is the SMP table the one in the book labelled GenGas? I think I know what you’re talking about.
Thanks Cody, i think i should try with a tig nozzle, tested some yesterday, heating a nozzle with propane-torch to glowing red, dropped it on the concrete-floor and no cracks.
Only to come up with a way to mount it to the airpipe.
I don’t remember if it’s a table from SMP in the book Gengas, but think this table i used is somewhat newer, around 1974, if i find it i’ll post it here.
Did I count 12 nozzles in your firetube, I never heard of a 12 nozzle Imbert design. On the leading cutting edge here.
Hi Goran, I also first installed a ceramic nozzle from a tig welding machine in a charcoal gasifier, but it melted quickly, and then I replaced it with a steel one made from a piston bolt made of high-alloy iron, which withstood all tests.
Hi Bob, now when you say it, i actually have to count them,
i was pretty sure i had 10, but i remember the dimensioning table had different alternatives, from 8, up to 12.
Im going to take some better pic’s this weekend, when full daylight and everything cleaned.
Hi Tone, thanks for the information, maybe i should try with piston-bolt, easier to connect (weld) to the air-pipe also.
But i just remembered i have some nozzles from a scrapped original Imbert heart laying around, made of Kanthal, (ni-chrome alloy) one of them should work.
I had to guess because part of a picture was missing. As far as I know I am the only one who has built 12 nozzles in a WK Firetube.
Hi Bob, i had to go out counting them, it was 10,
Anyways i know SMP used 12 in some, and i think Vesa Mikkonen used 12 nozzles also.
I too dislike the cheramic stuff. Also problems occur if you want to inject water. It will thermal shock crack. Like tone sayd, good steel with a lot of mass and a good thermal connection to distribute the heat is the way to go.
You know Tone I haven’t thought about this but you could make this have a changeable nozzle if you use pipe. Use a cast iron pipe coupler for where you drill the holes. That way if she melts, you aren’t entirely out of the project.
Sounds like a WK Firetube to me.
That is an interesting and easily made idea Tone but do you think that the pipe above and below the nozzle in the hot zone would last long? I like the idea of the coupler for the nozzle Cody. I think a union with hole drilled around may be more durable. Either way it won’t be coming back apart after it’s been in the reactor.
Bob, it IS. Also like a flute. They both work on the same principe.
