I like the way you think Jeff. I’ve got or can get a lot of good stuff like that. Need any hydraulic cylinders?
Hi Andy, I was just thinking about making a small wood chomper but more like this one.
So, yes cylinders are on the list.
Hi jeff
The size of your timber harvesting equipment really contrast with your equipment wood processing!
Why?
Hi Thierry, I guess I don’t understand the question. The sawmill will cut from a 6’ to 20’ and from 6" diameter to maybe 30". The Chomper will take any length to up to 14" diameter. The skid steer will twitch a good size saw log. One in the video was 18’ and not sure of the diameter, maybe 26" diameter. That about as large of a log I want to saw on a manual mill. The tiny skidded is for mainly pole wood for the Chomper and a few small saw logs. I want to grow fast growing pole wood and the tiny skidder would work nice with a smaller version of the Chomper. Of course the small chopper would have a charcoal fueled clone. Vary little or no chain saw needed. If the pooh hits the fan I can not keep the big stuff going but the small stuff will pull me through the hard times. Found the time to change the engine canola oil in the little skidded.
Hi Jeff
Very nice forest site Jeff
I noticed that your firewood processor is professional quality (certainly very productive). The small skid steer is handcrafted (I like simple solutions).
Thierry
Jeff
you use canola oil for the engine?
Going on the third year, I think. Don’t use it below 30°F. Would like to find a local oil plant or grow something. Should use a blend but haven’t found the time. I would not try it in an expensive engine. Clones were made for experimentation.
Wow, that is a big toothpick!
Your on Mr. Wayne… ![]()
You sure have a nice office to work from!! Little slice of heaven.
Reminds me when they pull one of those boa snakes out from under a house, it just keeps coming!!!
That log puller should shake off most the snakes.on some big logs.
Hi Jeff
Farmers here grow much canola “transgenic” .this cultural cause me some problems professionnels. I am beekeeper and bee not endure this type of agriculture industriel. I dislikes encourage this production (except to replace the dyno juice)
Do you have a recipe suggest?
Thierry
Hi Thierry,
It’s been a few years since I read this stuff so I forget the details…
https://www.hort.purdue.edu/newcrop/ncnu02/v5-029.html
very interesting Jeff, thank you very much
Specifically, do you use 100% of food canola oil to make engine oil?
Or mix differing oil you together?
Thierry
Hi Thierry,
Right out of the jug and into the engine, 100%. I wish I had the time to make a mix and grow or glean my own seeds. I bet even more could be figured out.
Also, I want to make some kind of oil filter. Possibly an oil cooler. Maybe a transmission oil cooler and maybe some kind of a pump to run off the engine. Maybe a Detroit fuel pump… An oil cooled engine would be cool.
You are definitely someone very surprising.
Squeeze your oil yourself?
Have you tried the vegetable oil for chainsaw? This is a problem I would solve .Use of mineral oil to lubricate the saw chain is very rawhide:
For two or three years. Switch to synopsis before it gets too cold. Have not squeezed my own oil yet. Need to get one of those expelled made from a wood drill bit. ![]()
Really? Drying in one day??? Are those little trees that you cut to chunk— which would mean the wood is “green”. I use dead fallen limbs for my wood and still dry it for a few days. TomC
